painting axles
Discussion in 'The Garage' started by K5Greek, Feb 4, 2007.
  1. K5Greek
    K5Greek 1/2 ton status
    Nov 25, 2005
    2,054
    Vineland, NJ
    what did you guys use for primer/paint? gonna start sandblasting my 14b tomorrow and the 44 in a week or two..
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    We have a paint over here called Hammerite. They do a smooth version which is what I use. No need to primer on keyed surfaces, it even goes straight over rust. When you scratch it up, just touch it up. Not a show finish but tough and practicle.
  3. littlejimmythatcould
    littlejimmythatcould 1/2 ton status
    Feb 6, 2006
    797
    Clovis, NM
    I plan on using rustoleum on mine when I get a 1 ton set to swap in. Will probably brush it on because it goes on thickker.
  4. K588
    K588 1/2 ton status Premium Member
    Feb 19, 2005
    332
    19
    Westminster,Maryland
    Metal etching primer and Krylon Semi flat Black.
  5. UPS
    UPS 1/2 ton status
    Aug 2, 2006
    438
    Maine
    POR 15.
    It's really tough, you can hit it with a hammer and it doesn't chip.
    I painted a piece of rusty scrap steel with it and left it outside for 2 years and the rust didn't come through the paint.
    Just paint it on with a brush and it lays on really flat.
    Mike
  6. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I used the cheap walmart **** and it has worked so far:D.
    Ira
  7. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
    If your going thru the trouble to sandblast it, at least make a reasonable attempt to do it right...
    some zinc and epoxy primer in rattle can will do ya... then it doesn't much matter what you put on top of that.. Imron, rustoleum, whatever... proper priming is key to durabilty..
    rant on...
    it amazes me that people will go thru all the trouble to blast, then just slap whatever they have in a can on there...
    gotta rusty one? slather the POR15 or Rust Bullett on to your hearts content.... fresh steel? do it right...
  8. K5Greek
    Nov 25, 2005
    2,054
    Vineland, NJ
    well i was gonna primer/paint with a few layers then smother it in some por15 cause i can get it free
  9. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
    yeah, sorry, i should have prefaced that with saying it wasn't directed at anyone in particular...
    just a body guy peeve of mine...
    just make sure you topcoat the por15... and i would strongly suggest the zinc i post about all the time... THE best thing you can put on bare steel... i'd do zinc, epoxy, sand, por15, topcoat...
  10. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
  11. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    ya i just used a wire wheel to clean em up then painted them with cheap wally world rattle cans...lol
