Painting Chrome ***UPDATE ***
Discussion in 'The Garage' started by behemoth, Aug 4, 2002.
  1. behemoth
    behemoth 1/2 ton status
    May 16, 2000
    1,833
    Northwest Florida
    I have factory chrome mirrors. I want them black. I'm going to clean them up, shoot them
    with primer, then flat black. Any opinions out there regarding this? Anyone have any pitfalls
    I should watch out for?
    *******UPDATE********
    Just reinstalled the now-flat black mirrors. They look pretty good! The bumpers
    are the only chrome left now (well - door handles and trim strip down the side -
    haven't figured out how to deal with those yet). Door windows get tinted to 20%
    on Monday. /forums/images/icons/laugh.gif
    I sanded them initially with 80 grit sandpaper, then smoothed them out with 400
    grit wet/dry. I put two coats of primer on and two coats of flat black. After I get
    the window tint, I'll post a link to some pictures. The 4 inch lift will have to wait
    until spring (ack!), so it's cosmetic / comfort stuff for now (i.e. cheap mods). /forums/images/icons/laugh.gif
  2. lizard
    lizard 1/2 ton status
    May 11, 2002
    114
    Tallahassee, Florida
    Re: Painting Chrome
    I think there is a prep solution you need to apply be fore painting. The reason is to etch the chrome enough to give the paint something to stick to. Otherwise sandblast it off..
  3. LlanoK5
    LlanoK5 1/2 ton status
    May 26, 2002
    202
    Llano, Tx
    Re: Painting Chrome
    You will need to prep the chrome in a manner that will let paint stick to it, otherwise the paint won't stay put. Sanding it with a course sand paper should work, but you must make sure that the chrome is roughed up pretty good, then clean it with a grease remover. Spray the primer, let it dry then sand it with about 320 sand paper, wipe down the surface with tack rag to remove the sanding dust. Then paint, you may need to do two coats to get a good finish.
    Kirk
  4. behemoth
    May 16, 2000
    1,833
    Northwest Florida
    Re: Painting Chrome
    Yeah, I thought about rubbing them down with some 600 grit wet/dry sandpaper.
    What kind of grease remover are you talking about? Can't I just use dishwashing
    liquid? Two coats of primer?
  5. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    Re: Painting Chrome
    hell id just get some other regualr ones and do it like the ones one my dads im not sure what they are..they are just painted steel i guess not the chrome ones..and then paint those..there are pics of them in my webshots..they are white..
    Bryan
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    Re: Painting Chrome
    use some course steelwool it will cleen it and ruff it up for painting you can also use the fine stuff to cleen glass and chrome /forums/images/icons/grin.gif
  7. behemoth
    May 16, 2000
    1,833
    Northwest Florida
    Re: Painting Chrome
    Thanks guys!!! /forums/images/icons/laugh.gif I figure $8-$10 in paint beats the 'ell outa $40 (+ shipping) from LMC.
    Now, if the temp outside ever drops below 95, I'll go out and start working on it. /forums/images/icons/tongue.gif
  8. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    Re: Painting Chrome
    no problem /forums/images/icons/grin.gif
  9. LlanoK5
    May 26, 2002
    202
    Llano, Tx
    Re: Painting Chrome
    Steel wool is good for cleaning chrome, but it won't scuff the chrome enough to get the paint to stick it. You'll be repainting them from time to time. Start with about 80 grit sandpaper, and work your way to 320. As for the degreaser some say the gas works, but I've always used DX330, it's a professional grade degreaser that most body men use. You might also want to put on two coats of primer, to help avoid rusting.
    Kirk
  10. behemoth
    May 16, 2000
    1,833
    Northwest Florida
    Re: Painting Chrome
    80 grit?? Really? /forums/images/icons/shocked.gif I gotta put major ruts in it? 80 grit will damn near take the chrome
    off, won't it? Is DX330 something I can get at pepboys or similar? I was thinking
    about giving it two coats of primer anyway, just to be safe. Thanks! /forums/images/icons/laugh.gif
  11. behemoth
    May 16, 2000
    1,833
    Northwest Florida
    ... see UPDATE at top .... /forums/images/icons/laugh.gif
