Painting fiberglass
Discussion in 'The Garage' started by hammermachine, Jul 19, 2006.
  1. hammermachine
    hammermachine 1/2 ton status
    Aug 23, 2005
    2,450
    6
    Still in New Jersey!
    Is there any special prep needed to paint the fiberglass cap for my truck. It's kinda old any discolored. As part of my "new paint job" I need to change the color from off white to black or OD green. Any thoughts, thanks.
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    In a word, yes! It needs special prep and paint otherwise it'll just crack and flake off. Have a chat with a body shop that does a lot of Corvette work. They'll be able to tell you what you need.
  3. BL1TZKRIEG
    BL1TZKRIEG 1/2 ton status
    Jan 4, 2005
    196
    OREGON
    I was wondering this as well
    can you buy the paint and do it yourself?
  4. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
    i just spray painted mine, with cheep spray paint, it was black and the el paso heat turned it green!!LOL
  5. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,030
    1,347
    Kzoo, Mi
    I think that if your gelcoat (the colorcoat) is in good shape you can refinish over the top of it, same as metal.
  6. ryoken
    Jun 13, 2003
    29,622
    1,374
    Jersey Shore
    yup, sand, prime and paint... nothing too special about it...
  7. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    if it is gel-coated, just scuff and prime and paint. if it is kinda raw or the gel coat is cracking, sand the whole thing with 240-grit, use and epoxy primer, then use a 2k primer surfacer then sand with 600-grit and top coat. don't bother sanding the epoxy primer...it will just gum up the paper.
  8. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    ok, bringing up a somewhat old thread, i`ve been wanting to paint my cap black,flat black, and its not the smooth cap, its like textured, anything need to be done before painting? i`m really just looking to change the color, not make it perfect really...also what paint should i use?any one ever hear of krylon`s fusion paint?
