Painting in cold temps
Discussion in 'The Body Shop' started by dontoe, Mar 10, 2005.
  1. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Does it hurt anything to paint when the temperature is say in the 50s?:confused:
  2. flatline
    flatline 1/2 ton status
    Sep 9, 2004
    167
    Cincinnati, Ohio (area)
    if you want it to set right just follow the directions on the can, I always paint 70 degrees or higher cold paint just clots up and looks crappy
  3. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    it'll take much longer to dry and it'll run easier... but generally, no real adverse effects... throw a heatlamp to it after you spray...
  4. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Keep the spray paint in the house so that the cans are nice and warm....
    Then at least it will spray cleanly and lay down well. My spraypaints are all sitting at about 10 degrees (F) right now, so I am pretty sure they're all ruined... :frown1:
  5. mikayak390
    mikayak390 Registered Member
    Mar 3, 2005
    70
    NJ
    depends on the brand. I have been using dupont paint for my thunderbird. I started on a saturday morninglast fall at 65 degrees. The interior was done in about two hours and came out nice and smooth. when I started the trunk and exterior later in the day the temp had dropped to 56. The side of the car was also out of the direct sunlight for most of the day. The paint just bubbled on contact with the metal. I have had that problem many times before with rattle cans and cold metal. At $100/unmixed quart I decided my bird can stay in the nest till spring.
    I am far from an expert painter, but I was using low temp hardner/reducer a top end paint on clean sanded starlight primer. I have excelent results with the same combo in the past I had to assume it was the temperature.
  6. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    Like posted above, keep the cans warm and try to heat up the metal before using. I made a make shift paint booth with heaters tarps and a blow dryer worked well for spray painting in the snow. Check my webshots for the tent........oh and be careful of the fumes if you go this route.
    Jesse
  7. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,092
    492
    Grand Rapids area
    I've done it in the garage. I put a halogen lamp on the part to be painted for a while (those cheap 400W work lights) and before painting I soak the rattle cans in a bucket of hot water.
    Ventilation is another issue...
  8. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    hehe, my old boss had a hotplate at work for those cold winter days.... ;)
    we do that stuff at work.. crank the heat the whole night before.. turn off in the morn and paint a couple hrs later.. the substrate is all nice and toasty.. :D
