Painting Leaf springs, what paint to use? Please help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dasanii19, Dec 8, 2006.
  1. dasanii19
    dasanii19 1/2 ton status
    Oct 11, 2006
    344
    NV
    I figure while im going to be messing around with my brakes why not take off my leaf springs and kinda "restore" them.
    Once I get the front leaf springs off are there any tricks or tips I should know about before dismantling them? I mean will they spring everywhere if I try to take them apart?
    Should I sand them by hand or should I beed blast them? what grit sand paper do I use or what grit sand do I use in the sand blaster?
    What type of primmer and paint do I use?
    Should I get them re- arched?
    To get the old busings out, do I use a torch? and how do I get the new ones in? hammer?
    Are there any "kits" or anything I need to buy to do this project? Or is it pretty much- take them apart-sand them-primmer them-paint-re-assemble-install new bushings and thats it?
  2. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Here is a link to the Technical Articles section. It regards a 52" spring swap but the beginning of the article describes a tear down and rebuild of your leaf spring packs.
    http://coloradok5.com/52inchspringswap.shtml
    One of the other guys here, B_to_C used industrial grade Rustoleum on his suspension parts and it worked great. A bit pricey though. Any engine enamel or epoxy base spray paint should work well enough.
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I have used Hammerite spray paints with very good results under my trucks. Looks good, lasts a long time, and stops rust.
  4. basketcase
    basketcase Registered Member
    Apr 30, 2005
    52
    buffalo,ny
    my paint preference is chassis saver from magnet paints, a little pricy, but stops rust and requires minimal prep. just knock off any loose rust with a wire brush and put on the paint.
  5. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    I used regular old rustoleum auto primer and cheapo black paint on my springs in that 52" spring write-up... works for me... and its cheap.
    j
