painting ORD's Crossover Steering Parts
Discussion in 'The Garage' started by MuddinManny, Dec 4, 2006.
  1. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    Hey Y'all,
    I have a question. I want to paint ORD's Crossover steering parts, i.e., lift block, steering arm, drag link, and the HD Tie Rod I bought. However, they are all smooth steel, not much for paint to bite into. Is there anything I need to do special to these parts, or can I go spray happy with the Rustoleum?
    Thanks,
    Manny
  2. 86dieselburb
    86dieselburb 1/2 ton status
    Oct 20, 2004
    219
    Crestline, CA
    Funny you should ask this. As I just installed mine this weekend. I have first hand knowledge. If your gonna paint it, scuff up the parts with some 120 grit. But be forewarned you will scratch the paint putting the xcross over stuff on.
    If I had to do again, I'd wait and paint after you get it all hooked up.
  3. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    Thank you very much! That's just what I needed to hear! Not only will I wait for it to be installed. I'll wait to get it back from the alignment shop! Cool beans!
    Thanks!
    Will a regular wire wheel work, like the type used for cleaning an axle, or does it need to be done by hand with the 120?
    Manny
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    yep same thing happened to me:haha:
  5. 88k5blazin
    88k5blazin 1/2 ton status
    Nov 27, 2006
    484
    clark new jersey
    when i put all my stuff on i just painted it just the way it came and have not had a problem with it chipping or peeling but i'm sure sanding it a little wouldn't hurt either
  6. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    unless its a show rig you don't need to do any prep before paint. just wipe it clean. Brand new steel is the best surface to paint over. I painted mine in the truck only because I am impatient and couldn't wait to get it on the truck.
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Just don't paint the bottom of the steering arms were they touch the knuckles, and that the top of the knuckles that touch the steering arm are not painted. You want a bare metal on metal contact surface with no paint, grease, lube, etc. Use brake cleaner to get them totally clean when you go to mount the steering arm.
    Harley
  8. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    sand with 120, prime it with good auto primer... install everything... wipe it all down just in case it got some grease on the primer or something... and THEN rattle can paint it the color you want.
    j
  9. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    Hey Y'all,
    Thanks so much. I hear everyone! This site is awesome! Y'all are helpin' me build my dream truck. Can't wait to show her off!
    Manny
  10. mtn. burb
    mtn. burb 1/2 ton status
    May 13, 2004
    1,260
    Ojai Calif.
    Same with me. Just cleaned it, painted, installed. No problems. Just hit the 1.5" tierod with a fresh coat yesterday after 2 years of abuse.
    You'll love it. My truck turns on a dime. Used to be I was breaking drivers side spring pack bolts, took a football field to do a U-turn. Now it turns a radius with 39.5's like my wife's 2WD Suburban.
  11. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    I'm gonna go a little different direction here....
    for quickest, longest lasting results without getting crazy, I'd just put a few piss coats of zinc chromate on everything, then rattlecan to your hearts content... It's self-etching primer and will make the parts sooooo much more durable than just blasting em with paint.. 1 can'd probably do all your parts easy...
  12. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,127
    56
    Powell, Wy
    mine were painted blue and now orange in this rig. Originally I just painted the bare metal. This time to change color I ran over it with some emery cloth or something wiped the dust off and rattled. you can always touch up to
