Painting Plastic
Discussion in 'Interior - Stock & Custom' started by jimmy1984, Apr 10, 2007.
  1. jimmy1984
    jimmy1984 1/2 ton status
    Jan 12, 2007
    153
    Napa CA/Oconomowoc WI
    i have some plastic panals that i want to repaint and i was just wondering what the best procedure would be for doing this they are already painted and i want to redo the paint because who ever painted them before didnt know what they were doing. any suggestions on procedure or type of paint to use?
    Any help would be much apriceated
  2. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    Obviously removing the existing paint should be the first step. Clean well. I've had LOTS of luck lately with both Krylon Fusion paints, and also Tremclad "Plastic Primer". The Fusion you just spray on the color coat, but theres only so many colors to choose from. Tremclad Plastic Primer is just what it sounds like, primer for plastic. Shoot, let dry, then shoot with any color paint you wish.
  3. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    SEM Colorcoat... designed for that stuff, works awesome... Sprayable vinyl dye also does a real good job, but isn't nearly as simple..
    strip the old paint off... wet scuff pad the item thoroughly... wash the part down a couple times with hot, soapy water, very important, interior pieces love to fisheye from years of Armor All-ing...
  4. mr.smartass
    mr.smartass 1 ton status Premium Member
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    I believe Krylon also makes a plastic primer, I got mine from Lowe's and did some hub caps, worked great! Goes on clear and you can use whatever color you want. But Ryoken seems to be the resident paint guy so I wouldn't question his authority either. :waytogo:
  5. dyeager535
    26,979
    What kind of wear are you getting from the painted surfaces? I know a couple people that have painted door panels, etc., but the paint seems to wear off pretty quick. I've gotta paint my Tuffy console (or sell/trade it) and I'm a little nervous that the padded vinyl won't look good very long with use.
  6. jimmy1984
    Jan 12, 2007
    153
    allright thanks guys i will probably go way of krylon fusion
  7. thedrip
    Dec 13, 2003
    1,129
    Chattanooga, TN
    I've been avoiding painting any kind of "high traffic" plastic. I just don't see ANY paint lasting.
