Painting the dash? WTF????
Discussion in 'The Garage' started by Jeremy_C, Jul 10, 2002.
  1. Jeremy_C
    Jeremy_C 1/2 ton status
    Mar 26, 2002
    1,381
    East TN
    Can you paint the dash in your rig? the local idiot was telling me that you can paint the dash, and it will look good. This may be possible, but since it the person who told me this has a reputation as being just plain stupid, i took the tip with a grain of salt. My current dash is brown, an i want to paint it grey, reckon it will work? /forums/images/icons/laugh.gif
  2. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    i know you can strip them and dye them but i dont know about paint...
    Later
  3. Jeremy_C
    Mar 26, 2002
    1,381
    East TN
    this has got to be one of the most active forums, either that or there are alot of people like me who cant sleep right now. 2 minutes after i post, iv'e got a reply an 6 views. This place is great /forums/images/icons/grin.gif
  4. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    aint it though...i meant to add to my last post...check with an uphosltery/interior shop and see what they can do...thats who dyed mine for me
    Later
  5. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    Dyed mine with vinyl dye without stripping the old finish off. Worked fine. Check into SEM vinyl dye. I couldn't seem to find it on the timetable I set up, so went with some cheapo stuff, but the color turned out exactly like what I wanted and so far has held up very well. SEM has a vinyl prep that I would recommend using.
  6. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    You can paint them.. Auto part stores sell the paint. Mine was cracked.. I bought a good used one that was grey from a fellow CK5er and painted it blue. It is over a year old now and still looks good..Dan
  7. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    I bought and ised vinyl paint, black over blue. Worked great and lasted too.
    Ken H.
  8. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    I painted the vinal dash pad and plastic door panels on a '70 challenger once. It worked pretty well. You just got to make sure that you have a very clean]/b] surface before you paint it. The hard plastic stuff requires a plastic primer first. High use areas may need a touch up everyonce in a while but it works good if your not going for show quality.
  9. bouncytruck
    Oct 11, 2001
    858
    Bothell, WA
    I painted the vinal dash pad and plastic door panels on a '70 challenger once. It worked pretty well. You just got to make sure that you have a very clean surface before you paint it. The hard plastic stuff requires a plastic primer first. High use areas may need a touch up everyonce in a while but it works good if your not going for show quality.
  10. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    I painted the Bezel the gray color as my side panels are OEM gray.
    I bleieve you can dye the Vinyl darker, but not lighter.
    Good luck.
  11. Grim-Reaper
    7,385
    Atlanta
    Cleaned mine with denatured alcohol and painted it Krylon Kakie. /forums/images/icons/smile.gif Held up fine for 3 years except where my suction cup phone holder rubs on it.
  12. TopOff
    Jan 16, 2002
    1,760
    Folsom, ca
    That looks like a GREAT Paint job!
    I will have to try this too!
  13. Jeremy_C
    Mar 26, 2002
    1,381
    East TN
    That looks GOOD!!!! I guess it does work /forums/images/icons/wink.gif
  14. Grim-Reaper
    7,385
    Atlanta
    Did a lot better than I thought it would. Did the door pannles also. The truck was blue when I gotit. The dash has done great but the door pannels around the lock has pealed. I don't think I got them clean enough. Thats a spot where hands come in contact often and I think there was some oils and crud there. The arm rest have held up good also so go figure. The dash is a vinyl as are the arm rests. The door pannels are a plastic, probably a polyproplene.
    Polyproplene plastics (same stuff they make 2 liter coke bottles out of) are darn hard to get stuff to stick to it. I use to do specialized printing on stuff like cups/mugs. The polyproplenes we had to flame treat to get the inks to adhear. Something about that plastic give off a slight oil of some sort and Flame or plasma treatment was the only way to get it off. It basicly burned it off.
