painting the hardtop?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Bross82, Jun 24, 2002.
  1. Bross82
    Bross82 1/2 ton status
    Feb 11, 2002
    215
    Spencer, MA
    hey, i was thinking about painting my hardtop red... is there anything i should know about doing it? the top is black, i was told i should use 2 coats of gray primer first then a couple coats of the red paint and then a coat of clearcoat.
    also, another person mentioned i should ask about making a smooth hardtop.
    thanks,
    matt
  2. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    I think you should sand off all the originaly paint first with some 100-200 grit sand paper. But thats about all, the rest sounds right. Of course im no proffesional. /forums/images/icons/wink.gif
  3. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    I am going to do the samething. I am going to smoth mine they look good. I dont see why what you have been told would not work as long as you hit it with a pad to rough it up a little and clean it with laquer thinner first.
  4. Bross82
    Feb 11, 2002
    215
    Spencer, MA
    thanks a lot
    matt
  5. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    WEAR A BREATH MASK WHEN SANDING!!! /forums/images/icons/cool.gif
  6. sinchphoto
    sinchphoto 1/2 ton status
    Mar 7, 2000
    366
    Southern California
    i painted mine black use to be blue.
  7. Bross82
    Feb 11, 2002
    215
    Spencer, MA
    thanks for reminding me,
    matt
  8. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    When sanding a fiberglass hardtop, you must be careful not to sand too deep. If you do, you will be able to see the strands of fiberglass. /forums/images/icons/frown.gif I painted mine black after it being gray then painted all of the sliding window parts to match. Looks really cool. The body now has some mods. from Clayton though. /forums/images/icons/frown.gif Biggest mistake on the whole rig was having an expensive paint job put on it.
