Painting The Top
Discussion in 'The Garage' started by 85-454blazer, Feb 26, 2006.
  1. 85-454blazer
    85-454blazer Registered Member
    Feb 26, 2004
    14
    North Carolina
    Hello...my issue is insignificant to the expert advise I see being offered on more technical subjects, but, how/what should I use to repaint my black top? I don't want to remove it right now...maybe in the future. Looking for a quick, easy, recommendation with appropriate paint material. Thanks, Jerry
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Depends on how you good you want it to look?
    I painted mine with semi gloss spray paint. Turned out good,and has lasted almost 2 years without any touch up.
  3. smalltowncowboy
    smalltowncowboy 1/2 ton status
    Jan 16, 2006
    503
    hermiston oregon
    kinda depends
    well now that all kinda depends on how your going to paint it. are you going to rattle can it? or do you have a spray gun to use? ive seen some people put spray on bed liner on their tops, but in my opinion that ads unwanted wieght.
    either way you go the basics are the same. spend more time on prep work.
    sand, clean, tape, primer, paint. optional clear coat.
    hope this helps you.
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i did the same, no prep no nothing, jus taped the windows and went at it. came out decent
  5. Janitorjim8
    Janitorjim8 1/2 ton status
    Feb 21, 2005
    215
    Illinois
    repainted mine black about a year ago, didnt sand it, but did clean about 3 times with a strong cleaner, then went over it with one of those 3M pads. I used a spray gun with a fiberglass paint and it turned out real nice
