Painting Tips
Discussion in 'The Garage' started by axiomaticdesigns, Dec 9, 2005.
  1. axiomaticdesigns
    axiomaticdesigns Registered Member
    Sep 23, 2005
    7
    El Paso
    I have searched on line and found a few helpful articles on painting my own truck. Has anybody painted their own vehicle? What problems did you run into? Any help or tips would be appreciated.
  2. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    Basically it depends on the quality of job you want. Dry air is a must, along with sufficient volume. A clean booth area is quite desireable too. Practice a few panels before painting, and maybe do more research on home painting.
  3. mr_clean
    mr_clean 1/2 ton status
    Sep 21, 2003
    348
    Sacramento, CA
    I painted mine. I went with a base coat / clear coat because I was told it was easier to correct mistakes.
    I think I have a pretty good paint job for my first attempt. Just as was said earlier, practice on test panels. the different layers will flow differently. Epoxy primer will flow differently vs high build vs paint vs clear.
    I put up clear plastic in my garage to make a cheap spray booth and it worked great. It is more difficult to move around in but it does work. Keeps the overspray from dusting everything too.
    Good Luck,
    Scott
  4. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    ensure ure air is clean and dry and oil free!! run it thru a filter. clean paint area is nice. i used to wash the garage floor with a hose before i painted.
  5. big_black_blazer
    big_black_blazer 1/2 ton status
    Dec 19, 2004
    114
    Western Kentucky
    put a box fan in your garage doorway so that it will draw outward, and close off around it with plastic.
    clean the truck and shop. don't skimp at all.
    try to move as little as possible so not to stir any dust you may have missed.
    paint the roof, then the hood, then the rest; you don't want to drag your hose across fresh paint.
