Painting Wheels
Discussion in 'The Garage' started by FL84K5, Aug 4, 2002.
  1. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    I'm thinking about painting my stock wheels a gloss black. What would be the best way to do this? Any special paint to buy? I can use all tips, never painted anything like this before /forums/images/icons/tongue.gif
  2. jackedjimmy
    jackedjimmy 1/2 ton status
    May 18, 2002
    195
    Redmond WA
    I painted mine black with a paint called hammerite. It's normally a brush on pain but i thinned it and spayed it on after masking the chrome parts. It doestake a special thinner called xylol to thin it ...not paint thinner.
    It came out pretty good nd has a hammered finish
  3. FLASHLIGHT76
    FLASHLIGHT76 1/2 ton status
    Jun 20, 2002
    255
    OREGON
    A buddy of mine used the Dura liner spray bed liner which you can get in a rattle can from wal-mart. It cam out awsome and is increadably scratch resistant. I'm doing my axles in it and it is so user friendly and you can touch up anytime and you can't tell you did.
  4. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    well..my dads just painted his stock steelies with regular red spray paint to match the truck looks fine to me..some pics of it in my webshots...
    Bryan
  5. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    If your doing them will they are steel on the tires you could use vasaline on the tires.. The paint won't stick to it...Dan
  6. Z85WT1500
    Z85WT1500 Registered Member
    Aug 2, 2002
    5
    Michigan, USA
    Agree with the vaseline, but I painted mine with just regular DelStar enamel, it's lasted 6 + years...
    Jason
  7. TwoCrowsDesign
    TwoCrowsDesign 1/2 ton status
    Jul 13, 2001
    387
    You can also get Hammerite in a rattle can. I did my receiver with it and it looks and lasts great.
    John
  8. Bret73
    Bret73 Registered Member
    Jul 22, 2002
    19
    Utah
    Try some POR 15, it's pretty awesome, you can spray it or brush it, I've used the little foam craft brushes and the finish comes out pretty good, and it's very durable, plus no primer necessary.
  9. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Prep work is the key to any good finish. Make sure they are very clean. Then sand them to rough up the surface. Clean with mineral spirits. Then apply a primer then a topcoat. Use light even coats.
    John
