painting wheels
Discussion in 'The Garage' started by georgiared84, Feb 27, 2003.
  1. georgiared84
    georgiared84 1/2 ton status
    Sep 5, 2002
    487
    Austell, Georgia
    I'm wanting to paint my stock rally wheels black. I was thinking about sand blasting them with the old tires on and the weights taken off then primering and painting them with the old tires on then driving it to the tire shop to get them changed. Anyone tried this, does it tear up the valve stem or anything else I should consider?
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Why do it with the tires on? That would take care of the valve-stem problem because you could cut it out.
  3. georgiared84
    Sep 5, 2002
    487
    Austell, Georgia
    Because I need to drive it up to the tire shop to get the new tires put on. My other truck is temporarily out of service.
  4. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    Shouldn't hurt the stems unless they keep thr blaster on them long enough to burn up the rubber.I would suggest that you at least primer them quickly as they will rust fast after blasting them. /forums/images/graemlins/thumb.gif
  5. blazerboy72
    blazerboy72 1/2 ton status
    Mar 29, 2002
    260
    hiram ga
    i sand blasted mine and painted them. i just taped the valve stems up.
  6. georgiared84
    Sep 5, 2002
    487
    Austell, Georgia
    Hi Neighbor. Thanks. I'm wanting to go to black wheels with the chrome rings. I already blasted and painted the caps black. I replaced the cap bolts with Stainless steel bolts and put on new studs and lugs. We'll see how it looks when I'm done. (Poor man's new Wheels)
