Pan gasket on 6.2?
Discussion in '1982-Present GM Diesel' started by protechk5, Dec 11, 2006.
  1. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    Whats the best seal for a pan gasket on the 6.2? A cork one? Or should I just use rvt or something? Also how hard it is? Looks like a pain in the ass with the engine cross memeber. I think the rear main is leaking too, how hard is that? I wont be doing that until my tranny swap in the spring or so.
  2. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Heard lots like a one piece rubber seal but they are hard to find.
    No suggestion for RTV or cork, I 've used them together though.
    Easy, once you get the tranny out:D Use a one piece, not the rope loking thing.
  3. protechk5
    Sep 26, 2004
    2,015
    VA
    I just read that if you have a 2 piece rear seal, you can do it with out dropping the tranny and t case??? Someone please tell me I have a 2 piece rear seal!
  4. BKinzey
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Sure, you probably have a 2 piece, that's what's leaking:doah::haha: The 2 piece is the rope one. If you are going to drop the tranny in the spring might as well wait unless it's a bad leak:wink1: and install a one piece then.
  5. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    All the 6.2's were two piece rear main seal. Some early ones got the crappy rope seal, and later ones got the hard grooved rubber seals. Mine was that hard grooved rubber seal. Rope seals were also two piece...
    The pan gasket set I got was that thick heavy paper with some coating on it. I used gasket glue to stick it to the pan intself, then put a thin coat on the engine side of the gasket and installed it. I have no leaks from the pan or the rear main now.
    The rear main is a PITA, and I can't imagine doing it with a tranny still there. You need to make a small wooden dowel tool to push out the old upper half, and push in the new upper half. The Haynes and Chilton's books actually cover this repair in some detail...
    Rene
