Panel Adheasives
Discussion in 'The Body Shop' started by BKinzey, Dec 29, 2006.
  1. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Can't weld so I'm looking for reccommendations on specific panel adheasives to use.
    I've got a few rust through spots in the floorboards that I want to patch. The floor will be covered so it doesn't have to be perfect seams. I plan to use pop rivets to hold the panel in place.
    Also is it better to attach a panel on the exterior or interior of the floorboards or does it really matter?
  2. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Fusor and 3M's offering seem to be the most popular...
    trim your rusty areas back.. overlap your patches 3/4" to an inch.. put plenty of adhesive, so it oozes out everywhere.. remove excess.. easier to just patch from the inside.. drag a brush over your seams afterward, top and bottom, to seal it up...
  3. g_mo
    g_mo 1/2 ton status
    Dec 28, 2004
    131
    tx
    I Was Wondering About These Products Myself. I Guy In Our Body Shop Said It Isn't A Good Sustitute For Welding Because It Will Eventually Come Loose From Vibration.
  4. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Eh, I haven't played with em much when it comes to bodywork.. mostly boats.. I do like the corrosion resistence built into the product.. i take every precaution when welding patches, cut to fit, weldthru primer, etc, but you never know...
    They make some incredible urethanes/epoxies nowadays.. work really well, but many have a "replacement life" to them.... I know there are some in the marine industry that have 5 to 7 yr time till they need to be redone.. The Fusor seems to be the most often used in automotive, many, many panels are glued nowadays, factory and repair...
  5. greywolf
    greywolf 1/2 ton status
    Oct 18, 2001
    1,606
    ST.PAUL TX USA
    fusor: if preped right no worries
  6. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    SEMS patch panel adhesives. i use them all the time at the shop, most commonly for attaching aluminum blocks to the inside of a front cap for support to the chassis. once its on, its NOT coming off. supposed to have a 5 min working time, mispositioned one once, and at 10 minutes it tried to pull it off. ended up tearing a hole in the fiberglass cap to get it off.
