Panhard ideas and pics?
Discussion in 'The Garage' started by camok5, May 9, 2005.
  1. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    959
    13
    Buellton, Ca
    I searched and I read the posts in the gravity forums but I still would like to see some pics of panhards on leaf spring trucks with crossover. My blazer is a daily driver and I have really soft deaver springs and a six inch lift. I am also going to inboard the shocks in the rear when I put my MOO anti wrap set up on so I know the blazer is only going to get more boat like and I want to try and regain some of its on road drivability back.
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Don't inboard the rears. Keep the shocks out as much as possible(on top of the spring plates is good) and straight as you can, that will help a lot. I'd like to see pictures of peoples setups with panhards on a leaf spring setup. The only ones I can remember being posted were not well done at all. I'm still debating running a panhard when I setup my rig. I likely will not and just wait till i can afford the coilovers and 3 link it.
  3. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
  4. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Your going to get less shock dampening which would only make the soft spring issue worse.
  5. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Ding ding ding, when you inboard shocks you're reducing the length they travel vs. the length the suspension cycles. Think of putting your shocks right next to each other on top of the diff. pumpkin and you get the picture. In some cases it's the solution and in a lot it's not.
    I would also like to see a well done panhard rod setup...so TTT for ya.
  6. camok5
    Jun 25, 2003
    959
    13
    Buellton, Ca
    I realize that inboarding can make it worse but i have been bottoming out my shocks and need more travel plus I dont want to go through the body(takes up to much room inside). I do plan on running the MOO inboading set up so I can move my shocks a little closer to vertical but I might change that set up down the road if it does make it to spongy.
  7. camok5
    Jun 25, 2003
    959
    13
    Buellton, Ca
    So nobody has any pics. :frown1:
  8. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    If you want to get rid of the boatyness of your blazer get some good shocks. My suspension is VERY soft without shocks, the point where its almost impossible to corner at speed, but with the high quality rebuildable mono tube shocks I have it drives very nice and corners very good.
    As far as the panhard bar goes, you need the draglink and panhard bar to be the same length both mounted on the same angle. If not it wont work, and this probably means that your going to need to run a draglink to the tierod or something of that nature.
  9. camok5
    Jun 25, 2003
    959
    13
    Buellton, Ca
    I agree that I need better shocks, right now I am running rancho adjustables but plan on switching to the bilstein 5150's or maybe the mx6 resevoirs but I dont know much about them. I understand how my panhard needs to work but would still like to see some pics of how people have mounted them, all the ones I have seen were not set up right.
  10. zcarczar
    Feb 10, 2002
    2,495
    I dont think ORD has any pictures of the setup they used to run on Wally. You could look on www.race-dezert.com and get some ideas from there, but I have been looking and there isnt too much info the the panhard setup. There is also a thread in teh Center of Gravity forum concerning this topic and I havent checked it lately to see if there was any pictures in there.
    As far as shocks stick with the Bilstiens or go with a 2" Sway Away, Fox or King. That way you can tailor the valving for you truck and really make those deavers work the way they are supposed to.
  11. camok5
    Jun 25, 2003
    959
    13
    Buellton, Ca
    Any reason for going with the bilstiens over the mx6 because cost is a little bit of an issue and I cant afford Fox or Sway Aways.
  12. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    More here:
    panhard on wally in past years
    It tends to bind the springs up and will do very little for your cornering but will tighten up the steering and take care of the bumpsteer. My panhard was a little too short and I could tell in a certain circumstances. It was still way better than without it.
  13. zcarczar
    Feb 10, 2002
    2,495
    From what I undersand is the Mx6 is really just a gimic, spend the money and get bilstiens. Its better to wait awhile longer and buy good shocks then have to buy shocks twice cause you bought crappy ones.
    Those are good pictures Stephen, I was wondering if you have any of them. I think when I build my new frame for my blazer im going to either run a modified factory setup, or go with a panhard bar and leafs.
  14. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    if you're looking for monotubes you might try...
    bbcs-15
    j
  15. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Ideally the panhard and draglink are the same length and are parallel as viewed both from the top and the front.
    That isn't to say that something else won't work. If they can't be in the ideal arrangement then want you need is for the two arcs to be "complimentary" thru the suspension's range of motion. In other words, you want the two different arcs to lay right on top of each other as best as possible. There will be a "Sweet spot" range where they mimic each other and outside of that range they will pull away from each other. You want the range to start a little below ride height and to be mostly above ride height. This will minimize the effects of the bumpsteer.
  16. camok5
    Jun 25, 2003
    959
    13
    Buellton, Ca
    I would love to see more pics of wally's steering if anyone has any and has anyone run a panhard and high steer. I want to see where your mounting points are.
  17. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    There's some pretty good shots in the custom rigs section of our page, just imagine your pitman arm where my idler arm is and you'll be able to get it put together. I doubt mine would work with leaves though. The pics I posted before are about as good as it gets with leaves and a panhard. The only thing I would do different is stick the driver's side of the panhard outboard of the frame rail a few more inches to make it closer to the draglink length.
    Jason, (zcar) if you're building a frame, DO NOT stick with the leaves. I know what you want and it's not leaf springs. Go to coils. I have some ideas on ways to make leaves work well for long travel systems with panhard bars and by the time you're done with the monkey motion you might as well 4 link it or run some radius arms. The only reason to keep the leaves on a high level fabricated vehicle is for the rules. If you want to race class 3, we should talk about some different ideas using leaves, otherwise, join the round spring crowd.
  18. camok5
    Jun 25, 2003
    959
    13
    Buellton, Ca
    After looking at the pictures of wally I think I could do a similiar set up but I would not be able to run high steer( to much stuff in the way) without more modification then I could handle. Because I run an ORD crossover draglink with the bend would I use a straight line to measure it to match the panhard bar and would ORD or somebody else be able to make a panhard bar for me if I made the mounts?
  19. camok5
    Jun 25, 2003
    959
    13
    Buellton, Ca
    still would love to see some more pics of a panhard set up?
  20. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We can thread a panhard tube up for you, no problem.
