Discussion in 'OffRoad Design' started by camok5, May 13, 2005.
  1. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    Buellton, Ca
    So if I came up with the measurments and made the mounts could you guys make a panhard rod for me and what would be the best ends to run, heim joints, bushing style etc. Also where do you think the best mounting point would be( dana 60 - behind the steering box on the drivers side and end of the axle tube on the pass. side?)
  2. Stephen
    Sep 15, 2000
    Carbondale Colorado
    We can do the tube, no problem. I ran heim joints on mine, 3/4 x 5/8 on one end that was in double shear and a 3/4 x 3/4 on the other end that was in single shear. I don't see any reason to run a different end unless you need to bend the bar, then you might want a bushing on one end. Your mount location seems to be pretty much dead on. Take a look at the pics in our tech tips section and you can see what I did a few years ago, that might help.
