Park lights turn on when I brake?
Discussion in 'The Garage' started by cochino12, Dec 8, 2004.
  1. cochino12
    cochino12 1/2 ton status
    Dec 23, 2003
    563
    Parker, Co
    allright when I brake my parklights are lighting up now? I also noticed my horn and turn signals have suddenly stopped working? Where the heck to I even start checking for problems? Thanks in advance for any help
    __________________
  2. sublmnl1990
    sublmnl1990 1/2 ton status
    Nov 8, 2004
    419
    Virginia Beach Va.
    check the flasher thingy mabob its not a fuse but its a...... round or square thing plugs in where the fuses go its called a........ damn cant think of it relay thats it.
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    also check the 4 wires that run to the taillights inside the framerail on the driver side. Mine were all melted together when one light came on they all did:yikes:
  4. ryoken
    Jun 13, 2003
    29,622
    1,376
    Jersey Shore
    <<<Mine were all melted together when one light came on they all did>>>
    mine did the same a few months back...
  5. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    It sounds like you are somehow getting contact between your tail light and brake light wires some place. Maybe they have been rubbing together and wore through the insulation and the wires are making contact? Do your brake lights come on when you turn on your parking lights?
  6. folkenheath
    folkenheath Worthless Trash Premium Member GMOTM Winner
    Nov 12, 2004
    4,269
    159
    Wisconsin
    Once you get the turn signals working by fixing the flasher or the short. The next thing is to see where your brake light wires are touching. Turn on the left and right turn signals, do the parking lights flash too? With both directions? If it only flashes with one side then you have narrowed it down to which two wires are contacting each other. I had a similar problem and that is how I found it, it turned out there was two wires pinched together in that same 4-wire harness that runs to the tail lights. Then later on it happened again, I swore I fixed it right. Well this time it was a different problem, one of those "Hoppy" plug in trailer wiring connectors was shorting out inside of itself, cheap crap.
    Good luck man.
  7. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    I would check the bulbs to make sure none of the filaments are touching one another. Did you do ANY work to the truck shortly before this started happening?
  8. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Sounds like two wires touching or a bad ground. I would check/clean the ground wire for the rear lights. If that doesn't help, then look for pinched/shorted wires.
  9. cochino12
    Dec 23, 2003
    563
    Parker, Co
    Ok I am an idiot. After all the searching for grounds, broken wires, bulbs etc. it turns out that the hazard button was on but it doesnt flash so I didnt know it was on. Thanks for all the replies
