Park pawl stripped in one direction....?
Discussion in 'The Garage' started by mikey_d05, Dec 7, 2005.
  1. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I've been putting this off since I still have an e-brake in my trail truck so it doesn't bother me right now...but that could change very soon. The last time out I was pounding on my truck pretty good. Everything help up very well. I went to put it in park on a downhill slope and took my foot off the brake to depress the e-brake (I drive two-footed when I wheel) and the truck made a clicking/whirring noise and started rolling forward.
    I figured no big deal, the park pawl is stripped, I can live it. I stuck it in gear, shut it off, and put the e-brake on. Later in the day I forgot about it and put it in park while pointed uphill, took my foot off the brake to engage the e-brake and then realized the the transmission was holding it's position...
    I don't know jack about the inner workings of an auto nor do I pretend to. Anybody have a clue as to what's going on? It's a 700R4 that was rebuilt a while before I bought it. I didn't think it could be stripped in only one direction unless I'm losing it. This truck/transmission isn't worth a trip to the shop if they're gonna have to tear into it. Any advice is more than appreciated.
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    no the parking paw can not only strip in one direction maby you just have a few teeth missing and the second time you missed the broken ones. How far did it roll the first time. And alos you know that putting a auto in gear when the truck off is the same as netural it will not hold you at all
  3. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    it will hold it while its running, he said he put it in gear, and then shut it off.
  4. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    I tried it repeatedly throughout the day with the same result. Unless I was consistanly hitting the same spot I'm pretty lost as to the cause.
    Yeah, I know an auto tranny in anything but park is like neutral. I just didn't want to put any more shavings into the transmission if the e-brake slipped a little.
  5. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    I don't know about a 700R4 but I had a similar problem on a Th350. The pawl came slightly loose. I just got in there and tighted the armature. Problem solved.
  6. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    I'll give that a whirl when I have time to tear into it. I might have time to tear the motor and trans out before I have time to fix it. :doah:
  7. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    if the bracket in the trans is loose it would be easy to fix just drop the pan and tighten two bolts i belive they are 13 mm if you want i can send a picture just let me know
  8. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Go for it man. As far as I know there's a little wizard in there doing black magic and voodoo to shift my tranny. :D
    Naw, I'm not that bad, but I'm not comfortable doing any advanced work on an auto either.
  9. gmtech954
    gmtech954 Registered Member
    Dec 6, 2005
    96
    ct shoreline
    also check your linkages its possible that when you parked the body was tweaked enough to hold it all the way in park therefore not fully engaging the parking pawl.
  10. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Also a good thought. It pops into neutral on it's own when the suspension is flexed a certain way. Could definitely be it as well. Cool that these are both pretty easy solutions.
  11. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    ****, whatever you do, DONT LET HIM OUT!!!:eek2:
  12. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    hmmm. that is very odd, and im quite intrigued.. let us know what it is, or if you have more questions...
  13. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Mine did the exact same thing. Years of use led to worn out body mounts and worn out shifter linkages, and some flexed out wheeling, basically led to the shifter not fully engaging park.
    Follow the shifter linkage from the firewall down to the trans and I bet you will find some really worn out pivot points.
  14. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    since it parks some of the time, I would be willing to bet money that it is a linkage issue.
    James
  15. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
