Parker Trip Spare Parts
Discussion in 'Rocky Mountain Region' started by marv_springer, Nov 15, 2006.
  1. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Post up spare parts so that we're not all takin' the same things.
    27 spline 208 case
    32 spline 208 case
    spare 12b rear shaft
    ** note1 ** - Some stuff you may not want to lend. Don't post it.
    ** note2 ** - If you break something and borrow it to get home, you will be expected to replace it in a timely manner.
    ** note3 ** - Did I lend my spare D44 shafts to anyone? I can't find them.
    Marv
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I always carry ( even though I will only wheel Saturday ) and could lend if needed in a pinch :
    12 bolt yoke , shafts , spiders
    10 bolt shafts front 28 spline and spiders
    spindles bearings locknuts
    draglink steering arm tierod spare condition only for driving home
    208 to 12 bolt rear driveshaft
    front flange driveshaft
    fuel pump , plug wires , plugs , rotor and ignition module for carb/HEI
  3. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Good idea Marv
    I'll have most all spares you could think of for 1-ton running gear.
    Shoot I still have a spare D60 carrier with gears from the trip to Moab :)
  4. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I am set up.
    Rear d-shaft and 205 yoke for a doubler or 203 in a K5.
    Front D-shaft 1" longer for doubler (4 bolt flange)
    D60 yoke
    Long side small D60 shaft.
    Tie rod low steer
    Stock draglink and arm 10B/D44 style
    Fred you by chance have any 30 spline stubs?
  5. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Naw I sold em awhile back.
    Hey Marv- I have a set of 44 shafts as spares for my K10. Want me to bring em?
  6. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Lemme see what all I got...
    I think I might have lent them to Mikey. Just had a whole set and now I don't.... :dunno:
    Marv
  7. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Only thing I can think of we could use a stock rear spring and a 4 inch lift front. Hopin I can get D44 axles lined up then I'm sure I'll be forgetting something.
  8. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am going to bring
    10 bolt 28 spline shafts, yoke, spindles, hub
    Front & rear driveshafts for a 208 truck
    stock steering components
    steering box
    4" lift mainleaves for stock length fronts & 52" rears
    I will have lots of other stuff that I usually do also.
    I was going to bring a 27 spline 208 but since Marv is going to have one I might skip it.
    Harley
  9. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    I will have 56" rears and a 4" front mains. Mechanical fuel pump, and an alternator.
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Matt, I'm not going to make this trip, too much risk after being down so long. Anyway, I've got some complete 30 spline shafts (30 outer/35 inner) your welcome to borrow for the trip.
  11. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    Thanx. I got some spare coming from a buddy next week.
  12. NateInChandler
    NateInChandler 1/2 ton status
    Apr 23, 2006
    418
    Chandler, AZ
    if we have some extra room i can bring some 10 bolt parts
    30 splines
    28 splines
    hub parts w/bearings
    a spare set of locking hubs
    drag link
    But then again, im sure everyone is running the good stuff and not 10 bolts, haha
    Nate
  13. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    mechanical fuel pump
    electric fuel pump
    shackles
    cap/rotor
    wires
    oil/t-fluid
    d44 shafts
    hubs
    u-joint for dana 44 axles, d-shaft and 14 bolt shaft
    spare front shaft
    spare rear straps.maybe yoke
  14. justhorsinaround
    Sep 16, 2003
    6,798
    Maybe a yoke?
  15. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I will also have:
    RH 1 ton TRE
    stock steering stuff (draglink, steering arm, cones, studs)
    water pump
    alternator
    some ujoints (1350, S44)
    stock 10bolt knuckles
    wheel bearings & races
    27 spline 208 tcase
    fluids, etc.
    Harley
  16. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Exactly :D
  17. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Harley,
    If you bring a 27 spline case, I will bring only a 32.
    Marv
  18. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Is your 27 spline case known good? My 27 spline seems to function ok but I am not sure of its true condition. I will go ahead and bring the 27 spline anyway.
    Harley
  19. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    ha ha :rolleyes:
    those yokes are a bitch to get off, so dont blame me for not getting that one, anyways, the truck no will have that issue, limiting strap and track bar will be in place:D
  20. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    anyone have 15 spline d-60 spares, I have quite a few, but only 35 spline innners and outers. no 30 spline sorry
