parking brake cables on 14 boltFF
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TheBlazerKid, Jan 15, 2001.
  1. TheBlazerKid
    TheBlazerKid 1/2 ton status
    Apr 26, 2000
    259
    Raymond, Washington
    I am about odne with my rear axle swap from a 12 bolt to a 1 ton 14 bolt FF, My question is how do I do teh parking brake? teh FF is from a 84 1-ton pickup and it had REAL long brake cables, I woud like to just re-use teh ones from the 12 bolt but i dont think the cable and spring is long enough inside the drum? can I just loosen the linkage for the e-brake and slide it back to make teh cable longer?, but tehn would the spring be too short?
    THANX!
    Theres No Replacement for Cubic Inches!
  2. chevydude
    chevydude Registered Member
    Dec 10, 2000
    38
    mat-su valley alaska
    i used a 14 bolt out of a 77 3\4 ton pickup in my 79 blazer and the cables were the same length,you might try to get some 3\4 ton cables
    marcus
