Parking brake help?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chvyhs, Nov 10, 2002.
  1. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    How do I convert my 1978 FF parking brake to work with my 1990 Sub? The FF has the older style with the 2 short cables comming out of the backing plates and my Sub had the one long and one short cable comming out of the backing plates. I still have the most my old SF that I pulled out. Can I pull the cables out of that and put it in my FF?
  2. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    I just swapped in a 78 12 bolt in place of an 87 10 bolt. I saw the same problem as you. I switched the backing plates since the 10 had bigger brakes. That also cured the different parking brake cables. They looked like you could just swap the cables but I did not look into it too much.
  3. chvyhs
    Feb 12, 2001
    1,469
    I guess I'm going to have to just take things apart and figure it out for myself. Thanks for the info on rig, I appreciate it. /forums/images/graemlins/thumb.gif
