Parking Brake is bad!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TXsizeK5, Sep 4, 2001.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    My parking brake doenst work, any idea how to tighten it or fix it?? Thanks
    6in 87' K5 w/ 35" BFG muds.
    What I need: 4.57 gears, limited slip front, auto locker in the rear, KN filter, Force2 Catback, rear springs, SSR's
  2. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    No one knows??
    TTT
  3. Neil
    Neil 1/2 ton status
    Jun 10, 2001
    275
    Dothan,Alabama
    get the cable tightened is all. easy to fix. mine was bad. it would press the pedal to the floor. loose cable is all. they stretch over time. don't rely on the parking gear always.
    Neil H.. Alabama.. '78 K5 400ci 4x4 AT,AC,PW Cheyenne. '74 C10 3spd/floor 250ci 4x2
  4. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    whats a "parking brake" is it that extra foot pedal thats real small? HA!
  5. ArrowheadK5
    ArrowheadK5 1/2 ton status
    Aug 3, 2001
    252
    Northern MN
    I once drove my Grandpa's '82 1-ton Ford (sorry guys, it's an awesome truck, fully restored) about 15 miles with the parking brake on, didn't even notice because the gears are so low, until I smelled it! After that I just parked it in gear, but I don't drive in the city that much so maybe that's different.
    Four wheel drive, four wheel expenses...
  6. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Pop your drums off and see if the cable came loose from the levers - mine is forever doing that, especially on the right side.
    1 tequila 2 tequila 3 tequila Floor
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  7. Grim-Reaper
    7,385
    Atlanta
    Sometimes the parking brake not holding is an indication that the rear brakes are worn or out of adjustment. Before adjusting the cable for the parking brake make sure the self adjusters are free and tighten up the the shoes. If you get into mud the shoes will wear faster than the adjuster can keep up. About every 2 rides I have to manualy adjust up my brakes for that very reason.
    Also the bracket under the driverside door likes catching rocks and getting bent and that will make the parking brake work poor.
    It's not my damn planet monkey boy!
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
    75 Jimmy, Dollar
    79 Chevy Blazer, Her's
    70 Chevy Burb
    Grim-Reaper
  8. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    I have manual trany, so i really need to get the parking brake working, it works good on lvl ground but not so good on hills and stuff, im gunna get it tightneed this weekend thogh.
  9. ben794X4
    ben794X4 Registered Member
    Aug 29, 2001
    53
    Boise Idaho
    I had a manual 87 with the same problem now I have a 79 that also has this problem. I figured it was jut a chevy thing because it is common to all the chevys I know. Thanks for the tips about thightening the cable.
    Subvert the accepted paradigm.
