Parking brake options other that caddy calipers for rear disc- line lock???
Discussion in 'The Garage' started by COCHEV, May 13, 2003.
  1. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    i want to run rear discs and not mess with the cad calipers. i have a 4speed/208. it would be nice if there was a t case caliper for the 208 to go along with high anlge cv. /forums/images/graemlins/frown.gif
    anyways, has anyone used a line lock? if so, how much of a pain is it to install?
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    I would'nt trust a linelock for anything. Mico used to make a "brakelock" switch that did the same thing, held pressure on the brake's. Problem is, they bleed off, I've seen a couple of freind's hurt, and one killed from using them. /forums/images/graemlins/angryfire.gif
  3. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Line locks are cake to install...just cut and reflare brake line and install and bleed brakes. Some kits come with the pre bent line so there is no need to cut and flare line...Only problem is, if you use it as a parking brake, it will kill your calipers in much shorter order than normal use... You caliper seals aren't designed to hold that kinda pressure for extended periods of time...I am thinking about putting line locks on my Blazer, but mainly for wheeling and doing wicked burnouts../forums/images/graemlins/thumb.gif
    Chris
  4. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    a perfectly logical reason for this upgrade /forums/images/graemlins/thumb.gif burnouts are cool! /forums/images/graemlins/cool.gif /forums/images/graemlins/thumb.gif
  5. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Exactly, you must use line locks within there designed parameters...and you must still use caution...I mean, you wouldn't stand in front of a 500hp Chevelle that was roasting is Mickey Thompsons and was only being held in place with an electronic solinoid that is sustaining over 1500psi of brake pressure at the front calipers, would you?
  6. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    that is why i would rather have the t case brake. probably more work and $$$ then locating some cad calipers though. don't know of any other options though. if i had an auto i just wouldn't worry about it. but its anoying with a stick not having an e brake.
  7. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    nothing like big block power and and taking 15,000 miles of the tread life of perfectly good 37" MTR's right? Naw, I think they would be indispensible on the trial with a 4-speed, IMO...
  8. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Re: Parking brake options other that caddy calipers for rear disc- line loc
    You can use a hyd park brake for short term holding the truck in place, but I would not get under it or downhill from while doing so. The typical line-locks sold by Summit etc. require 12V power to maintain the lock. The Mico type locks use 12V power only to engage it, the line pressure holds it. Some of the Mico locks and the Jamar Park-Loc are manual engagement.
    For a t-case park brake you really want a drum. A drum holds better when static than a disc can, unless the disc happens to look a lot like a clutch. The best drum design will have an external contracting band, not an internal expanding shoe design. That allows they to be more self cleaning.
    BTW, it's rare to see brake line pressures exceed 1200 psi and most people only generate about 800 psi unless in panic mode.
  9. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I have/use the Mico Lever Lock (no voltage required) www.mico.com
    I don't use it for a parking brake for the same reason someone already said #1 the calipers will bleed off the line pressure in time #2 pre-mature wear on the caliper seals.
    I did a test with my Lever Lock by blocking the tires with wood, set the lever lock on/locked pumped the brakes to fill the lines with pressure then let it sit over night. The next morning I went out and kicked the blocks out, my K5 did not roll. I released the lever lock and my K5 started rolling down the driveway. This was just a test of about 14hrs I would imagine that as the calper seals weeken the time will be shortened???
    Oh one more comment on line locks.
    If you get a line lock I recomend the Lever Lock because the button style(12v required) is on or off no inbetween. I like to ease off the brakes while letting the cluch out on steep hills and such with my lever lock. Make for smoother starts /forums/images/graemlins/thumb.gif
    Good Luck
