parking break light is on
Discussion in 'The Garage' started by foolhardy, Jul 12, 2005.
  1. foolhardy
    foolhardy Registered Member
    Sep 16, 2004
    84
    the parking break is on in my k-5 but the break is not on is there like a fuse that i can pull or a wire i can cut or pull
  2. k5guyva
    k5guyva 1/2 ton status
    Oct 26, 2003
    165
    Southeast VA
    You can remove the bulb from the dash or fix whats causing it.
  3. mudslinger99
    mudslinger99 1/2 ton status
    Oct 8, 2004
    512
    East Coast
    Have you used the parking brake lately ?
    Push the break down and release a couple times.. Make sure the pedal comes all the way back up even if you have to pull it up by hand..
    Sometimes if it's not all the way up the light will come on even though it is not engaged..
  4. mr_blasto
    mr_blasto 1/2 ton status
    Nov 8, 2004
    495
    Irvine, CA
    you can do a search for this as it has been asked before. On my '72 there was a wire coming off the proportioning valve. If you disconnect it the light will go off - it was very simple to do. Check it out and see if your truck is similar.
