parking / e-brake cables
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jekbrown, Feb 2, 2002.
  1. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    I know this has been discussed b4, but a search didnt yield the answer for me. When I went from 4" to about 5.5" of lift on the rear of my rig, I found the drivers side e-brake cable to put pulled up against the spring....its to short. Can I swap in pretty much any e-brake cable? ie, ford super cab? 'burb? anything? If not, which rigs should I be looking to to raid for parts? I have half ton axels...are e-brake cables compatible from diff axels/drums? As always, *any* info is greatly appreciated!
    J
    See the on-going build up of my '85 Jimmy! <a target="_blank" href=http://community.webshots.com/user/jekbrown>http://community.webshots.com/user/jekbrown</a>
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    A cable is a cable. If you can find one that is the right length and can be made to attach in a manner that wont leave you second guessing then go for it. The 1/2-1 tons cables I've encountered didn't appear to be any different other than the length for the specific application.
    **WARN**ing, Something winching this way comes! [​IMG]
    <a target="_blank" href=http://www.mccords.s5.com/myk5/index.htm>NashvilleK5</a>
