Parking light, electrical ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5DRAGER, Jan 14, 2003.
  1. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    When I turn my lights on my left turn signal indicator on the dash lights up and stays on. But the front left parking light and left side marker don't come on. But they all work when I turn on the left turn signal. Was just wondering if this has happened to anyone else and what you did to fix it, and if not where is a good place to start. /forums/images/graemlins/1zhelp.gif
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Bad bulb. There are two filaments in an 1157 bulb. If the smaller one is burnt you'll have no park light but the signal will work...it will also light the dash indicator up when the lights are on.
    rene
  3. K5DRAGER
    Jul 27, 2001
    1,164
    Momence, IL
    Well I changed the bulb the other day and it didn't do anything. But ya got me wondering so I went out and tryed another one and when I removed the bulb from the parking light socket the side marker light came back on. So now I'm wondering If I have a bad socket or what? Any other idea's?
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    been having the samething happen, discovered that when the parkinglight doesn't come on the turn signal indicator stays lit all the time. Sometimes it works and sometimes it doesn't I can't figure it out. Same with the headlight on the same side, sometimes its bright sometimes its dim like its almost dead.
  5. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Could be a bad socket, corroded inside or maybe a broken wire...I just ran into that myself. I just wired up a new park light socket and all is well again.
    Rene
  6. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    You have a bad ground. Dim headlight is the clue to watch for. Check the small ground wire at the core support. It may be corroded...look for greenish coloring on the wire itself.
    Rene
  7. K5DRAGER
    Jul 27, 2001
    1,164
    Momence, IL
    Thanks, I'll let ya know what I find out, I'm going to try to look into it tomorrow.
  8. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    In the wiring on that side, there should be a brown wire. That is the parking light power wire. it splices and splits into 2 wires of the same brown color again near the headlights...one goes to the sidemarker and the other to the front parking light. I had this same problem just a few days ago. If that splice is bad...the turn signal part of the bulb will still work...but the park lamp will not.(there are 3 wires for that front parking lamp..1. ground 2. signal 3. parking lamp...if the ground and signal wires are good, then the signal works and the parking will not.)
    check out http://www.chuckschevytruckpages.com/80hlightschematic.html
    for a full harness wiring diagram
    Blake
  9. K5DRAGER
    Jul 27, 2001
    1,164
    Momence, IL
    Thanks, that will give me a place to start, if it gets warmer than 5 degrees today!
  10. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Just to chime in, it is most definitely the parking light wire. I have the same problem on my K20. If you go wiggle my socket (because the whole darn thing is loose from the bumper), the parking light will come on then go off. Its a bad wire and acts exactly as you are saying.
