Part 3 Gov-Lok Welded and installed
Discussion in 'The Garage' started by TrcksR4ME, Dec 3, 2004.
  1. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Project took a little longer than expected, but its all back together and I took it for a test drive. Even though I wrote down how many turns for each adjuster for the carrier bearings, I still felt like I was doing it wrong when I put it back together /forums/images/graemlins/screwy.gif I did notice a tiny amount of play between the pinion and the ring gear when it was back together and can't remember if it was like that before /forums/images/graemlins/1zhelp.gif I am guessing a little play is ok, and I mean a very small amount (though I am not a machinist type so I couldn't say accurately how much there is).
    All in all, my general feeling is that I could have done a better job, and I would not be suprised if the carrier bearings don't last too long. But if it fails then I'll just pick up another 14 bolt. I think I could do a better job welding a diff the next time around.
    I promised pics, but I am feeling lazy right now. I will try to post a few later on. /forums/images/graemlins/whistling.gif
  2. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Yeah there has to be play between the ring gear and pinion. This is what they call backlash. If you dont have enough, you will melt your ring and pinion set down. I think the spec is 0.008"-0.016" or right around there.
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Congrats! /forums/images/graemlins/thumb.gif Theres always more play at the pinion then the ring gear. I have no idea why, but it is normal.
