Part # check ?? GM alum intake on a TBI motor.
Discussion in 'The Garage' started by Stephen, Aug 17, 2003.
  1. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Did all the TBI motors come with an alum manifold?
    My bro's buggy motor came from a sub with a goodwrench engine in it but the manifold looks original.
    Part # on it is 14102182.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Our '94 Sub came with a factory aluminum intake, as did the TBI 4.3 in our '91 S-Jimmy. It's been a long time since I owned it, but I'm pretty sure that my '87 K5 also had a factory aluminum intake. /forums/images/graemlins/cool.gif
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I believe all TBIs are factory aluminum
  4. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    working at the junk yard i never saw an iron TBI intake.
    the part number on my TBI intake is the same as yours. and its out of an 87 truck k15
    grant
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Cool guy light weight racing parts, stock, how much better can it get.
  6. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    As far as I know they were all aluminum. Also the 4 bbl intakes were aluminum through most of the 80's. I know they were using aluminum as far back as 82 on the Z28's.
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I've never seen a factory aluminum 4 barrel manifold on a truck. And I wouldn't call a stock aluminum tbi intake, lightweight race stuff. Lightweight maybe.
  8. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    Got the motor swap in the burb 3/4 ton right now stephen....have a spare TBI manifold if you need one.
    And yes..it seems all TBI manifolds were aluminum.
    DW
  9. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Alot better -
    - The passages are T'd (shaped like a T), like the old Q-jet manifolds, disrupting air/fuel mixture as it enters the port.
    - Port to port flow can differ significantly. I had the CFM rateings written down here somewhere, can't find it at the moment, tho'. But I remember the readings being quite different (Port to Port).
    Typlical factory production part.
    The part works well enough to do it's job - and thats it.
    They didn't spend the time or money to build it around a flow-bench, they didn't have to, at the time.
