Part # for D60 TRE's
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TheLakeRat, Mar 1, 2002.
  1. TheLakeRat
    TheLakeRat 1/2 ton status
    Nov 29, 2001
    363
    San Angelo, Republic of Texas
    Part # for D60 TRE\'s
    Building high steer tie rod and drag link. I've seen the style that screw in each end of a tube and not with one short side and one long. what tie rod ends should i use? Thanks for the help in advance.
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    Re: Part # for D60 TRE\'s
    tierods
    es2234r
    es2010L
    draglink
    es2026r
    es2027l
    those not the ones you want?
    <a target="_blank" href=http://community.webshots.com/storage/1/v5/0/2/33/32300233Kkewdn_ph>http://community.webshots.com/storage/1/v5/0/2/33/32300233Kkewdn_ph</a>
    formerly 77chev
    still a jerk though
  3. CK5
    May 19, 1999
    21,623
    701
    CO
    ES2026 is what you want for all four ends, it is a high angle drag link end and what I used for my hi-steer, the 2026 is the one on top compared to a GM tierod end.
    <a target="_blank" href=http://coloradok5.com/temp/rodends.jpg>http://coloradok5.com/temp/rodends.jpg</a>
    Steve
    Director of Global Expansion
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    why? the 2027 is the mate to that joint with left thread so it is much easier to align.
    also, why would you need high angle on a tie rod that sees no angle?
    formerly 77chev
    still a jerk though
  5. CK5
    May 19, 1999
    21,623
    701
    CO
    Less chance of movement with contact to rocks plus you only have to cary on spare TRE since all four are the same. You need the hi angle on the tierod to clear the springs (they sit up higher).
    Steve
  6. TheLakeRat
    Nov 29, 2001
    363
    That's exactly what i was looking for guys. thanks a million. Now hopefully i can get my knuckles in so i can get this thing together in time for Moab.
