PART # FOR S/S BRAKE LINES
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BLUESMAN, Dec 28, 2001.
  1. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    I need S/S brake lines..Does anyone know if I need Pro Comp #7215 or #7220?I have a 81' 3/4 ton 10 bolt(frt).The rear is 14 bolt SF.Thanks.I need to order soon so I can finish installing the diffs!!!
  2. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Here is the shortcut to Summit for the parts you need... I think the PN you need is EXP-7220:
    <a target="_blank" href=http://store.summitracing.com/product.asp?d=4&amp;s=25&amp;p=2346&amp;SearchType=ECat>http://store.summitracing.com/product.asp?d=4&amp;s=25&amp;p=2346&amp;SearchType=ECat</a>
    <font color=red>GOT MUD???</font color=red>
    My license plate reads:<font color=blue> 8 YR SUV</font color=blue>
    454/TH400/NP205 - 14BFF/D60/w/ 4.10s - 36" TSLs
  3. BLUESMAN
    Oct 3, 2001
    951
    I was'nt sure since the early K/5's had the Dana 44 frt(mine does), but the later K/5's had the 10 bolts.So the 1/2 ton and the 3/4 ton 10 bolts are the same as far as brake lines?Thanks!
