Part identification help
Discussion in 'The Garage' started by Wishbone, May 17, 2006.
  1. Wishbone
    Wishbone 1/2 ton status
    Mar 6, 2006
    239
    Oklahoma
    Who can tell me what this is and what it does?
  2. broc944
    broc944 1/2 ton status
    Sep 23, 2005
    1,660
    Northern Minnesota
    Are you asking about the black round object with wires going to it?
  3. GEORGIA GABE
    GEORGIA GABE 1/2 ton status
    May 25, 2005
    1,070
    Conyers, ga
    is this a trick question, All I see is a starter.
    gabe
  4. Wishbone
    Mar 6, 2006
    239
    Oklahoma
    Yeah the big black huge cylinder shape thing. Are you sure that the starter? Seems pretty large. I thought maybe it was the oil sending unit. These pics are taken from underneath the Blazer and this sits on the passenger side right next to the oil pan.
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yeah, thats the starter. I've changed mine in the '85 K30 at least 7 or 8 times in the 10 years I've almost owned it.
  6. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
  7. Wishbone
    Mar 6, 2006
    239
    Oklahoma
    Starting to get the picture now, thanks fella's!:bow:
  8. broc944
    Sep 23, 2005
    1,660
    Northern Minnesota
    So much for my tactfulness:D . By the way, the answer to your second question on what it does, it starts your engine.
  9. jaros44
    jaros44 1/2 ton status
    Jul 12, 2005
    408
    Outside Phila. Pa.
    Doesn't that sound like excessive starter failure to you?
    Is this the norm, because i've never changed that many
  10. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    Ive changed a few too, usually happens when you get cheap reman units.
  11. jaros44
    Jul 12, 2005
    408
    Outside Phila. Pa.
    Ok I can see that, just wasn't ready to change out that many starters
  12. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    Damn that's a lot of starters!!! :eek1: :eek1: What are you doing, clogging them with mud and water and burning them up?
  13. thatK30guy
    Jan 12, 2001
    32,076
    55
    Nope. Just normal wear and tear. I got one lifetime warranty starter from Car Quest and even though these are cheap remanufactured starters, they are just that...cheap. Every starter I've replaced was free due to the warranty. But since I don't drive the truck that much anymore, I'm not pressured to buy a brand new GM starter anymore. I've been told a brand spanking new GM starter will stop the problems.
    BTW, the problem with the starters was the gear grinding against the flexplate. The more it ground, the more it wore the starter gear. Finally when it gets worn down so far, it just misses every time you turn the key. And yes, there were LOTS of grinding noises, too. Just too lazy and tired of changing starters I guess. :haha:
  14. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Dayum, did you ever try shimming your starter for proper flywheel contact?
  15. goldwing2000
    goldwing2000 Guest
    No ****. That's what I was going to say. Most reman units even come with a shim kit.
  16. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    I had to change mine out 5 years ago right when I got to Las Vegas. We hadn't been there more than a week. I bought a lifetime warranty one from Autozone and it's still running strong. I've bought a few things from Carquest, but I noticed that a lot of there stuff wasn't made or remanned very well so I stopped buying from them. :D
    Rick
  17. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yep, sure did. Problem was, the shims were putting the starter too far away from the flexplate. :doah:
    Turned out the flexplate was a cheap aftermarket one that was just that...cheap. When I blew up the tranny last summer, the counter weights (ext. balanced 454) flew off damaging the flexplate and blowing two holes in the bellhousing.
    I bought a new flexplate and also got another starter (number 8 or 9 now) and put those in with a newly rebuilt th400 I got off eBay. Today the setup works just fine and no grinding of the starter yet.
    I think the problem was the old flexplate to begin with. Ever since I bought this truck almost ten years ago, its always had starter problems. Now I have a new flexplate, starter and rebuilt tranny in it, the problems are gone.
  18. jaros44
    Jul 12, 2005
    408
    Outside Phila. Pa.
    Are you sure it was that big black round cyl. thingy with the wires going to it that you replaced? I still can't find my oil sending unit though. haha
  19. Wishbone
    Mar 6, 2006
    239
    Oklahoma
    :D
  20. goldwing2000
    goldwing2000 Guest
    Oil sending unit is on top of the engine, just behind the distributor.
