PART NAME ASAP! help
Discussion in 'The Garage' started by broncoman6524, Apr 28, 2007.
  1. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    on the manifold of a sbc, there is a sort of nipple thingy that has 2 vacuum ports one ont he top and one on the side...its behind hte carb on #6 cylinders intake runner. in that area...
    WTF would you call that? the nipple on the side of mine broke today wheni was swappin intkaes:mad: .
    HELP! lol
  2. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    heres a picture..
  3. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    dont know the exact name for it, but they sell them in the "HELP" or in the PCV/manifold breather areas of most of the autoparts stores I go to, should be easy to take it in and match what you need
  4. K5-newf
    K5-newf 1/2 ton status
    Nov 5, 2005
    236
    canada
    If you lived close to me i would give you one i got a few spare ones kicking around. Just got to a you pull it yard and look around for anything with a carbed v8 and put it your pocket :D
  5. NewUser
    NewUser 1/2 ton status
    Feb 13, 2007
    528
    Chattanooga TN
    its called a thermal ported vacuum switch ;)
  6. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    no it's not, it's just a vacuum port, the one one the back of the intake, main vacuum, primarly used for the vacuum modulator on a transmission that uses vacuum.
    and yeah,,,just go somewhere and steal it:rolleyes:
  7. mrdrinksalil
    mrdrinksalil 1/2 ton status
    Apr 4, 2005
    1,595
    Atlanta, Georgia
    x2...
  8. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    id do that excpet. this is my dd. and theyre all closed tomorrow. so id have to go on monday.
  9. goldwing2000
    goldwing2000 Guest
    JB Weld the hole closed and put a reducing tee into the larger line.
