Part # needed
Discussion in 'The Garage' started by 5trucks, Feb 21, 2007.
  1. 5trucks
    5trucks 1/2 ton status
    Aug 12, 2005
    169
    Yuma Az.
    What is a napa number for the seal that goes on the axle shaft? The one at the end of the inner shaft next to the ears? This would be for a d44. Looked at the parts # page but didnt see it.
  2. 5trucks
    Aug 12, 2005
    169
    Yuma Az.
    no-one knows? Damnit!!!!!!
  3. goldwing2000
    goldwing2000 Guest
    I assume you're talking about the outer shaft, not the inner shaft. The inner shaft seal is near the splines at the differential. The outer shaft seal is just behind the spindle and there are actually three pieces.
    Large spindle or small spindle D44?
  4. 5trucks
    Aug 12, 2005
    169
    Yuma Az.
    Hell, i dont even know how to tell the difference. Do you have numbers for both?
  5. goldwing2000
    goldwing2000 Guest
    No. What year is the truck/axle?
  6. 5trucks
    Aug 12, 2005
    169
    Yuma Az.
    Have no idea the year of the axle. It was scooped up at a yard and it was laying in a pile of other axles. The original somehow split in half when i hit the top of a bump after clearing the other two. Front axle did a huge smile at me. I'll measure the spindle and post up the inches when i wake up. I work nights and it's bed time.
  7. goldwing2000
    goldwing2000 Guest
    If you were running a 10-bolt before, you can just swap over all your old parts. At least then you'll know what year truck to buy new stuff for.
  8. lurtch-k20-(78-90)
    lurtch-k20-(78-90) Registered Member
    Nov 8, 2006
    55
    Troup, tx
