part not available???????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RESTORE89, Jul 12, 2001.
  1. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    I went to the chevy dealership yesterday to buy a bearing kit for the lower part of the steering column, where the column comes out of the firewall. all the bearings fell out, and this is what is causing my sloppy steering for the last few weeks, and they said i had to but the entire column shat and rag joint assembly $145.00, and all i need is a bearing kit. Has anybody had this issue, and what can i do to not spend 145 for a bearing???
    thanks
    chris
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Can you get the rest of the bearing out and possibly get a part number? If so, then you can go to a bearing wholesaler and get a similar bearing for cheap.
    <font color=green>MIKE</font color=green> - "Hukd on fawnics,werkd fer me!"
    <A target="_blank" HREF=http://www.geocities.com/emmettology101>http://www.geocities.com/emmettology101</A>
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Try calling a couple of different dealers - that should still be available as just a bearing kit, if not, another dealer is likely to have it in stock.
    <font color=red>What would Brian Boitano Do?</font color=red>
    <A target="_blank" HREF=http://pugsley.alloffroad.com>http://pugsley.alloffroad.com</A>
  4. 88streetblaze
    88streetblaze 1/2 ton status
    Jun 27, 2001
    314
    middle of sticks, oklahoma
    CRAP... that 's what it is. i am a little of subject but will your talking about gm parts four months ago i went to buy several little things the o-rings for the oil cooler which non of the parts store can get cause they are different shape and anti squeek kit for the gas tank cause i don't want a cheep one, well know that i am to that point everything i priced and looked up four months ago has been discontinued.....
    Disgruntled.
  5. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    It would not suprise it GM would only sell the whole shaft. my father inlaw's rag joint wore out on his s-10 blazer and the dealer would only sell the entire shaft. The dealer said the whloe shaft should be replaced due to saftey. Just sounds like they want the money.
  6. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Tried just getting the rag joint myself. My parts man told me the same thing. He is the best in my area. The computers dont let you look up jut that part anymore.
    My .02
    John
    '83 GMC Jimmy 4x4 ZZ4 Crate Motor
    '83 Chevy P/U 4x4 Sand Drag Racer, 578 RWHP
    '94 Impala SS
    '01 Chevy 2500HD w/8.1L & Allison Auto
  7. 88streetblaze
    Jun 27, 2001
    314
    you could run it through their parts locator IF you could look up the old number though. some times the stupid things people do dumbfound even me....
  8. RESTORE89
    Jan 31, 2001
    548
    CHAS SC
    i have not tried to remove anything yet, i wanted to have the parts in hand before i started so i could just put it back together. does not look like that is going to happen. when i take it apart where would i look for the numbers
  9. 88streetblaze
    Jun 27, 2001
    314
    that just it for the most part the only way to get the numbers is off the box it orginally came in or to have the dealer look it up, but once they have been discontinued the parts guy can't look up the part number.....retarded isn't it.
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Just go get a whole new column from the junkyard, they're about $50.
    Tim
  11. Emmettology 101
    May 9, 2000
    8,126
    FL
    Usually on the outside of the race or on the dust shield covering the actual ball bearings or rollers...
  12. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    All the auto makers must be doing this. A guy I work with Tried to just get steering shaft bearings for his Ford. The dealer would only sell him the whole shaft. I told him that he already got that when he bought the truck.
    I think they wont sell the indivdual parts because of liabaility reasons. Some body could just replace the bearings, and the shaft could break and they would get sued.
    You should be able to dissasenble the steering collum and get the bearings from a bearing supply co.
    <font color=orange>GOT HORSEPOWER?</font color=orange>
