Part number for D60 Caliper bolt/spring...
Discussion in 'The Garage' started by 90blzr, Jan 26, 2004.
  1. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    Someone said you can get them at the parts store but they have no clue what I am talking about.
    The little screw that takes the allen wrench and the spring that holds the caliper in place on a D60 front.
    Anyone got the part numbers or know who would have them.
    I can just take them off my other 60, but would rather just get a new one at the parts store if possible.
    Thanks/forums/images/graemlins/thumb.gif
  2. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I don't have the part numbers off-hand, but Napa had a kit that contained the slide, spring, and bolt. Maybe try asking for a caliper hardware kit.
    Fortunately my local Napa guy is pretty good!
  3. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    So the kit you got contained 3 pieces? How much did it cost? I just called the local napa and he came up with the bolt and thats it /forums/images/graemlins/rolleyes.gif And they wanted $7 /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif
  4. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    Dont remeber the cost but a couple months ago i got my kit from carquest. The spring, clip and bolt are in the kit. Part number is 5562 i believe. I had some trouble looking mine up too and ended up finding it uner an 80's dodge one ton 4x4. Otherwise check this napa number UBP82135 it should be the same kit.
  5. burbBoy
    Feb 4, 2002
    358
    WI
    Oh and one other note.....there should be an instruction sheet with the kit also. I had problems with the stock size keys falling out. I finally measured it like the kit says and found i need an oversize key. It sucks when they fall out on the trail!
