Part number for NP205 shifter mounting bolt?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fredekr, Apr 1, 2003.
  1. fredekr
    fredekr Registered Member
    Jul 12, 2002
    92
    Colorado Springs, CO
    Does anyone know the GM part number for the NP205 shifter mounting bolt? It's the bolt that the shifter pivots on, mine goes into the NP205 to TH350 adapter plate. My local dealership couldn't find any such thing... /forums/images/graemlins/rolleyes.gif
    thanks,
    Kevin
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    try #14009313
    That is just the bolt, it doesn't contain the grease zerk, b ut you can get the zerk at that dang cool hardware store you have down there where you just sit back and watch people pull stuff out of their butt that they think will work for you /forums/images/graemlins/thumb.gif
    Chris
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    try #14009313
    Chris
    I second all the above info, including the part number and watching people pull stuff out of their butts. /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif
  4. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    No wes you don't understand /forums/images/graemlins/rotfl.gif They have this hardware store down there in Boulder where the dudes will pull out EVERYTHING YOU need, count it for you, put it in a bag for you, LABEL the bag for you and staple it shut...you don't even have to touch a bolt until you get home... /forums/images/graemlins/grin.gif
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Hmmmmmm...kind of sounds like the homo who owns the local True Value store here in town! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  6. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I think it is thier iventory control...a lot of hardware stores end up writing off a lot of inventory as a bad debt because so many people put a "few" extra bolts in the bag....it really is a shame, but what can you expect from Boulder, eh, Kevin? /forums/images/graemlins/rotfl.gif /forums/images/graemlins/grin.gif
  7. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    That bolt - is it the same for all 205s or what? He said he has a 350/205. I have a 465/205. Will the bolt be the same?
    -- Mike
  8. dyeager535
    26,982
    191
    If I remember previous posts correctly, there are two different bolts, more than likely dependent on year.
    14009313 is listed in my '85/86 parts manual, so if there are any differences, an earlier adapter is more than likely going to be different, and not, say, an '87 or newer.
    If that part number works for you, great, but if you want to "keep your gm vehicle all gm" you are out of luck with the zerk fitting apparently. However, the parts manual is nice enough to give the specs on it: 1/4"-28x1/2" straight.
    Might want to do a search for posts on that bolt, as I'm fairly sure there are two different thread patterns.
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    -- Mike
    Yes, the bolt is the same and will work with all of the 205-equipped vehicles.
    BTW, there are 2 different bolts available. This part number listed above is the more desired one since it has the hole for the zerk fitting. The other bolt is just that...no zerk fitting as some shifters had the zerk on the pivot point on the shifter itself.
    Get this greasable bolt and be done with it. /forums/images/graemlins/thumb.gif
  10. fredekr
    Jul 12, 2002
    92
    Yup, probably had something to do with groovy trustafarian driving daddy's landcruiser thinking a few bolts should be free... /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/ignore.gif ... not that I'm bitter or anything /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif
    Sometimes they are over helpful at that store but I've gotten quite used to it, now I feel neglected when I go to other hardware stores where they don't hold your hand and find excatly what you need for you /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    Unfortunately, they DIDN'T have a bolt with a shoulder that fits right -- it's rattling like crazy now. I went ahead and ordered #14009313 from GMPartsDirect.com -- my local "stealership" wanted 2x as much $$ (yes, just another benefit of living in the Republic of Boulder /forums/images/graemlins/mad.gif /forums/images/graemlins/rolleyes.gif )...
    The junkyard said my adapter is from a '74, the shifter "should" be the same vintage... I'll let everyone know if it works...
    cheers!
    Kevin
  11. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    The 465/205 I bought originally was from a 1972 truck and it had a muchs smalle bolt hole in the adapter, I easily could've drilled and tapped it bigger, but I am cheap and a tap that big is not, so I swapped in another adapter I had laying around...
    Yea, Kevin, I got my bolt from gmpartsdirect too...if fact that is were I get most of my stuff, after I get the dealer to cough up the PN I need /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  12. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    14071955 - Boot Assm Shifter
    Boot has the trim ring impregnated into it...
    Can't find the invoice for the shifter though...first shifter i bought came with the bolt...years later when i converted the Chalet it didn't...but the design has changed...since the old spring washers are not ava...gm redesigned the shifter...where the bolt goes thru now has a isolater bushing like a spring eye...i have no rattles from my shifter.
    DW /forums/images/graemlins/usaflag.gif
  13. BILLY RAY
    BILLY RAY 1/2 ton status
    Dec 8, 2001
    1,319
    Austin, Tx.
    I have a brand new one still in the bag I can send you. /forums/images/graemlins/thumb.gif
  14. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Do yourself a favor and just order it from the dealer or get it from someone on here. I looked and looked and looked for a bolt that would work and found nothing. The threads are odd and the shoulder is of an odd diameter. I tried drilling out the shifters to fit a bolt that I could have MADE work but that just tore up my $20 bit. I tried going under size and putting a sleeve over the shoulder of the bolt but that didn't work either. I did a twin stick on the 205 and had a machine shop use the original bolt to make the new one from. They charged me $25 and included 2 grease ports for each shifter and the zirk. Pics are in the link below.
  15. fredekr
    Jul 12, 2002
    92
    Thanks for the replies everyone... I was too quick on the draw and ordered the bolt fo gmpartsdirect.com as soon as the part # got posted... lesson for the future, wait a couple days for offers from CK5ers first /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif at least two people have offered to send me theirs /forums/images/graemlins/thumb.gif
    thanks,
    Kevin
