Part number help
Discussion in 'The Garage' started by 77crewcab, Aug 26, 2005.
  1. 77crewcab
    77crewcab 1/2 ton status
    Feb 9, 2004
    1,620
    Lubbock, Texas
    I am looking for a part number for the studs for the exhaust manifold. The connection from the exhaust manifold to the exhaust pipe three studs and bolts per manifold. I tried having the parts guy at Autozone search and no luck (typical "Uh its not in the computer") Can anyone help me with this. I have Autozone, Advance Auto, Napa, and O'reilys close by just need a number to have them look up.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Their is a stud kit in the Help section . I can't remember the number . Comes with 3 studs and brass looking nuts .
  3. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
    Thanks, any idea what size/tread pitch I need?
  4. sponsoredbydad
    sponsoredbydad Dune Slaying Sand Junkie Premium Member GMOTM Winner
    Mar 12, 2004
    2,334
    405
    Dana Point "So Cal" "The sue me state"
    you shouldn't need a part # for those studs. use one of the nuts to size a new stud. your local parts house should be able to help if not stop going there.
  5. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
    Thanks I forgot all aboutthe old nut. The heat is starting to get to me. 97 on an asphalt parking lot under a black truck for about 8hrs per day the past week. :yikes:
  6. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    oem
    14088827 & 14088828 for the studs and 838780 for your nutz....
  7. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
    Is that from the dealer or where?
  8. diesel4me
    Jul 24, 2003
    17,577
    943
    Massachussetts
    What year???
    MOST chevy small blocks have 3/8" studs,but newer ones might have 10MM metric ones...they come in 2 sizes,one with a "heat riser" used 3" long studs,ones without used 1-1/2" studs..
    I never use store bought ones (being poor)so I made some out of long threaded bolts I had and chopped the heads off..I've found no matter WHAT I use for studs or nuts,brass,stainless,or whatever--they NEVER come off after 1 year of our wonderfully corrosive environment around here!..even with tons of "never seize"... :doah: :( ...I use 5/16" nuts and bolts if the stud holes go all the way thru the manifolds now--then all I have to do is cut the bolts next time--no pulling,drilling,and tapping the exhaust manifolds any more!.. :crazy:
  9. JIM88K5
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Dealer.
  10. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
    Thanks!
  11. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    I just had to get these myself. The HELP! ones is a fix it kit for 1 stud, came with 2 different length studs, 1 spring and 1 nut. And it was $8. And the short one was the wrong length anyway.
    My local parts store had them loose in a bin, so I got lucky, the dealer was next. He said he just buys them from the dealer and keeps them, because so many people ask. $12 for 3 studs, springs and nuts. They are all very different depening on emissions, exhaust setup. My right side on the '86 c10 had 1 short, 2 long because of a little emissions actuator mounted there.
    They are a BITCH to get out of your manifold too especially when broken. I had to use a welder and a spare nut, placed the nut over the broked stud, welded the piss out of it, waited for it to cool, and finally got it to move.
    Thestuds are are 3/8", but they have special threads on them to allow them to thread in, but not back out. The nut is a self locking type too.
  12. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
    Sounds like the dealer is the best bet then.
  13. dyeager535
    26,982
    190
    As an FYI, for later removal, I've had good luck using the really thick brass nuts. Not sure what they are called or what the application is for, but they are maybe 1/2-1" "thick", unlike the standard nuts that are what, maybe 1/4" at best? You can also use two of the "normal" thickness brass nuts to lock each other in place, but the bigger one is just easier.
    The brass won't seize to the stud, so you'll never twist the studs off like normally happens.
  14. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
    Would it be possible to just use some all-thread from the hardware store or would it back out as well?
  15. dyeager535
    26,982
    190
    I don't think allthread would be a problem really, except that it seems pretty flimsy. I could be wrong, I've not dealt with it much.
    I don't think those have a problem of backing out, I've never had the stud come loose.
