Part numbers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Suffergauge, Nov 13, 2002.
  1. Suffergauge
    Suffergauge 1/2 ton status
    Aug 1, 2002
    153
    Olympia, Wa.
    I have to replace everything from the rotor out on my driver side due to someone thinking it was funny to turn a hub. Does anyone know what the patr numbers are for any of this stuff? I have the number for the warns but <font color="red"> everything </font color> else it trashed. It is a 10 bolt. I guess I can always take all the busted stuff, throw it in a box, and take it to the part store and say I need this /forums/images/graemlins/1zhelp.gif .
    Thanks,
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    That's what I do /forums/images/graemlins/grin.gif
    The problem with asking for parts numbers is that you could get the wrong part.
    If you take your parts there you can compare on the spot.
    /forums/images/graemlins/thumb.gif
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    How was that caused by someone turning a hub?
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    so what does "everything" mean?
  5. Suffergauge
    Aug 1, 2002
    153
    Olympia, Wa.
    Everything refers too all but the axle, and the plate thing behind the brake rotor. Wheel bearings are history, the special nuts that hold it together are wasted, all the washers, snap rings, lock rings... destroyed, the part of the brake rotor assy. that surrounds the hub is cracked all the way around, and the hub is busted too! EVERYTHING
    This happened because the hub was intermittantly (sp) locking but not all the way. This cause the special nuts too loosen up and come off, therefore creating a big pile of red hot s**t!
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    nasty damage.
    I doubt the hubs locking would loosen your spindle nuts.
    sounds like the wheel bearing got wasted and cooked the rest.
    I have seen that in a d60 with water contamination
