Part time hubs needed!!!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Tommy, Jun 8, 2000.
  1. Tommy
    Tommy 1/2 ton status
    Feb 21, 2000
    260
    Alabama
    Anyone have any lock in lock out hubs to fit a 3/4 ton dana 44 axle. All it has now is the bolt on plat to make it full time. I called about new ones.......$190. I think I try to get some used ones. Anyone???
  2. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    IS your truck a '73-'78 3/4 ton? If so, you need the bolt on style hubs. Warn sells them, they shouldn't be over $70 or so. Check the 4 wheeling magazines.
    ken
  3. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    I suppose you have a full-time transfer case, right? Do you have a part-time kit already? You should get the hubs and the kit installed at the same time, or you'll acomplish nothing.
    <font color=blue>//////
    http://blazer79.coloradok5.com
    </font color=blue>[​IMG]
  4. Tommy
    Feb 21, 2000
    260
    Alabama
    Putting these axles under my 70K5, its got a 205, so alls well there. They do have the axle stuck out and lokks like 6, 1/4" studs holds the full time plate on.
  5. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    A set of Warn hubs should be a direct swap with the drive flanges. The local Advance Auto Parts carries Premium Warn hubs for about $70.
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    I called a few places because my friend has the same hubs and Warns hubs were all about $120.
    Do you need the whole hub or just the turn knobs??
    Mike
    1982 GMC Jimmy - Emmett
    http://emmett.coloradok5.com
  7. Tommy
    Feb 21, 2000
    260
    Alabama
    I need the whole hub, I have nothing there but the factory full time plate.
  8. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    I did exactly what you're doing, i paid around $80 for a pair at 4 Wheel parts, They're explorers, which are made by Milemarker, under license from Warn. $120 is way too much, hell, i paid to much, they aren't that hard to find and are a direct bolt on.
    RaisedK5
    "Friends don't let friends drive Fords"
