Parting out an unfinished project *MAKE OFFERS!*
Discussion in 'General Parts for Sale' started by BigOrange90Jimmy, Jul 3, 2005.
  1. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    Well, it was going to be the beater truck, but it's turned into a big pile of parts. Now they have to go!
    BRAND NEW REBUILT TH-350. 27 spline. Has been completely rebuilt and has been modified with a reverse-manual valve body. Includes new torque convertor. $800 neg.
    NP-205 T-case. Matches above w/adapter. Yoke front output. $150
    350 engine. Unsure of mileage, but did run before pulling and didn't smoke. $100
    D44/14b combo. 4.10's in both. Has flat-top knuckles and external hubs. I only have drive flanges for it though. $300 for the set.
    35x12.50x16 Super Swamper SSR's on 16x10 D-spoke chrome wheels. Includes new center caps and lug nuts. Tires have roughly 1/4" tread left. $200
    22 gallon stainless steel JAZ fuel cell. Has quick fill adapter and 45* fill neck with GM style sending unit. $200
    8" rear leaf springs. Unsure on manufacturer. Do need bushings. $150
  2. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    too bad you are not closer, i would be interested in all this stuff :doah:
  3. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    got dimensions on the fuel cell and maybe a pic??
  4. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    Here ya go:
    2' L
    20 1/4" W
    10 1/4" H
    12 1/4" H including the sump.
    There used to be a project vehicle on here. It's kind of ironic though, as his username was moneypit. This was a couple of years ago. He used it on his truggy. It hasn't been used since then. A little polish on the stainless and it would look brand new again. It has no dents and I'm even including a couple of A/N fittings, as well as the extended filler neck and breather tube.
  5. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    Also, I will work out trades for this stuff. I'll try my best to put everything I need on my "wants" list below.
    16x10 8 lug polished or black aluminum wheels.
    35x12.50x16 tires or metric equivilent.
    Front driveshaft 465/205 (10 spline) combo to 10b w/flange style output.
    Front 4" leaf springs/shocks/u-bolts/bushings.
    AutoMeter tachometer.
    CUCV front BUMPER/CUCV rear bumper and shackle brackets (I have brushguard and front shackle brackets).
    Conferr roof rack.
    Tilt manual steering column for 87 K5.
    Crossover steering setup including knuckle and steering box.
    12" subwoofers and amp. No box needed.
    Twin stick setup for 465/205.
    ...if i think of more I'll post them up.
  6. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    someone buy this ****e!
  7. bigcountryk5
    bigcountryk5 1/2 ton status
    Mar 13, 2004
    931
    G-vegas(Greenville) South Carolina
    you have a PM.... :D
