parting s10 project, PLUS MORE! VORTEC!
Discussion in 'General Parts for Sale' started by promudder, Sep 8, 2003.
  1. promudder
    promudder 1/2 ton status
    Nov 14, 2001
    117
    8 inch superlift rear springs with bushings=$200.00 + ride
    12 inch superlift front springs w/bushings=$200.00 + ride
    rebuilt dodge divorced np205 t/case=$400.00 + ride
    griffin aluminum radiator for v8'ed s10 or s15=$200.00 + ride
    b&m star shifter for 3 spd automatic's =$50.00 + ride
    dana 44 with 3.73 and flattops, 6 lugger=$150.00 + ride
    corp 12 bolt with possibly 3.07, not sure.=$75.00 + ride
    2wd steering box w/ drop pitman arm for crossover steer. =$100.00 + ride
    small block doorslammer headers 1 7/8 (run outside of frame) =$50.00 + ride
    built th400 2wd short, has 200 miles on it.=$200.00 + ride
    dana 44 housing (clearanced, cleaned, shaved)=$50.00 + ride
    email me if you need body parts
    also have
    eagle 4340 crankshaft and je forged pistons, if used with a 6 inch rod these will make your 400 a 415. =$500.00 + ride
    (4) super swamper LTB 34x10.50-16 on a/r baja's=$700.00 OBO
    these have 50 miles of driving to a mudrun, running in the mudrun and driving back home, FULL TREAD also these are for 6 lug.
    (4) boggers on a/r baja's, 16-35-16.5 have 1/2 to 3/4 tread six lug pattern,=$750.00 OBO
    1998 5.7 vortec engine with 10 miles on it, engine is apart, had an oil pump failure right off the bat, I work at a dealership, GM didnt ask for the engine back after they warrantied it, I bought it, toook it home dissassembled it, needs to be put back together, I already had the crank ground, you just need to put it back together. =$700.00
    new vortec heads are going for $500.00 alone! you get the complete engine for another $200.00 Engine is complete= throttle body to pan, distributor, intake, sensors, throttle body, everything!
  2. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    OK couple questions...
    First pics? Pics of crank and parts.
    Second As far as being ready to go back together what about bearings ans seals? Are they good.
    It had 10 miles on it, has it been sitting since 98?
    My dad is looking for a motor for his truck. Think it had a similar problem. Discount for picking it up? /forums/images/graemlins/grin.gif
  3. promudder
    Nov 14, 2001
    117
    sorry dont have pics, the engine will need gaskets seals and bearings, all I did was tear down and sent the crank to be turned. you will have to put it back together and buy whatever parts are need still (oil pump, bearings, plugs, gaskets, etc.) wont ship, that is pick up price. WILL SEPARATE THIS ENGINE.
  4. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    b&m star shifter. Do u have pics u can send me ? Is it like the Quick Silver? Is there a pic on their website? I am assuming it is a cable shifter. I call first dibs on this....
  5. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    you still have your s 10 and blazer frame?
    and the drop pitman ?
  6. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    the eagel 4340, is it nitrided? whats its specs and is it for a 400? will you seperate it from the pistons and what price?
  7. promudder
    Nov 14, 2001
    117
    NONESUCH= crank is nitrided, it has some scoring,3.80 stroke, 400 mains, cant separate(pistons would be useless without this exact crank, was a stroker kit for use with 6 inch rods. pistons are 4.155(.030 over 400).
    MONEY PIT= dont have pics, will try to get some tomorrow. this is the cheap t-handle finger release basic ratchet shifter with its own console base.
  8. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    Do you still have it?
  9. moneypit
    Sep 3, 2000
    1,382
    COLORADO
    How old is it and is it all there?
  10. promudder
    Nov 14, 2001
    117
    SF87K5= yes still have the d44
    MONEYPIT=shifter is 1 year old used 4 times, has cable.
  11. SF87K5
    Oct 27, 2002
    1,105
    How soon are you looking to get rid of that D44?
  12. moneypit
    Sep 3, 2000
    1,382
    COLORADO
    Cool I'm in /forums/images/graemlins/thumb.gif
  13. promudder
    Nov 14, 2001
    117
    sf87k5= It is not in my way, take your time.
    moneypit= Let me know when you want it.
  14. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Willing to seperate the heads? Also, do you have the exhaust manifolds?
  15. promudder
    Nov 14, 2001
    117
    yes will separate, $400.00 for the heads+ ride
    heads with valve covers and self aligning rocker arms $500.00+ ride
    new exhaust manifiolds, $75.00 each+ ride
    used exhaust manifolds, $30.00 each+ ride
  16. moneypit
    Sep 3, 2000
    1,382
    COLORADO
    PM me your address and I will send $$.
  17. jackedjimmy350
    jackedjimmy350 1/2 ton status
    Oct 20, 2000
    3,141
    Fort Smith, Arkansas 72901
    how far from the arkansas are you? might be interested in both sets of springs if we can maybe meet halfway... /forums/images/graemlins/thumb.gif
  18. SF87K5
    Oct 27, 2002
    1,105
    sent you a pm about the D44. /forums/images/graemlins/thumb.gif
  19. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    $400 for used heads? That's what they cost NEW!
  20. promudder
    Nov 14, 2001
    117
    moneypit= willdo.
    jackedjimmy= I am in kc. ks.
    84 chevy k10= Where exactly did you find brand new vortec's for $400.00? Would just like to know in case I decide to get a set again, JEGS nd SCOGGIN DICKEY sell them the lowest I have seen, and they sell them in the $250.00 a head. Ok lets see, that would be $500.00. And I bet you went to a car lot and told the salesman, 'This car is used it has 10 miles on it' these heads have 10 miles on them, they are still new in all senses. I could clean the golden oil off of them and say they were new, but I am an honest guy. If you dont want them fine, but dont go trashing my post, grow up already.
