Parts cleaning ideas
Discussion in 'The Garage' started by sandawgk5, May 5, 2005.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I do not have a parts washer and I am going through a Dana 60 and a 14 bolt. All of the initial looks at the bearings indicate they are fine but I want to clean all of the old grease out of them and repack them. What is the easiest way to do that. Can I soak them in simple green and rinse dry and spray down with brake kleen or will that damage them somehow. Any ideas are welcome.
  2. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Simple green... that chlorophyll stuff? I can't get that to do anything except turn things green in hue ;)
    5 Gallon buckets are incredibly useful, same with large rubbermaid trashcans :)
  3. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    carb cleaner from works awesome for everything and at walmart its cheap....like 74cents a can
  4. sandawgk5
    Oct 28, 2003
    6,881
    We used simple green as a degreaser all of the time back home. The key is you have to get the concentrate from sams or costco. Just use it straight and then hose it off. That is how we degreased our irrigation engine and it worked pretty good. But it sounds like Carb cleaner will work the best and it is cheap which is important.
  5. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Ahh, well concentrated anything will work well ;)
    Workin for Uncle Sam I have to follow all mixing instructions verbatim when dealing with concentrates, so I'm stuck with stuff like green-colored tools.
  6. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
  7. rdn2blazer
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    let me clarify that would be per axle.
  8. sandawgk5
    Oct 28, 2003
    6,881
    Thanks for the offer. I will have to think about that.
  9. rdn2blazer
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    just PM me if your interested and we can talk then. I think after you have spent 5, 6, hours cleaning it in your driveway and you get it "clean enough" and then when you rinse it off and the bare metal flash rusts a bit, you might find the 100 bucks aint too steep. :D
