Parts Cleaning
Discussion in 'The Garage' started by 454k30, Mar 4, 2007.
Cleaning parts
  1. Pour on the brake cleaner
    3 vote(s)
    30.0%
  2. Horse trough filled with gasoline
    1 vote(s)
    10.0%
  3. Take it to a dip tank
    1 vote(s)
    10.0%
  4. Some sort of media blasting
    1 vote(s)
    10.0%
  5. I'm still naked
    4 vote(s)
    40.0%
  1. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    Trying to rebuild another SM465. This one is heavily caked with 20+ years of oil and road grime. My usual hose down with brake cleaner didnt seem to make a dent. Any ideas on what would work to get this stuff off?
  2. Big Truck
    Big Truck 1/2 ton status
    Feb 19, 2005
    129
    hermiston, OR
    I'd try an assortment of wire wheels for a drill, it makes short work of the larger areas. oops I thought you were talking about the outside.
  3. 454k30
    Sep 13, 2004
    1,613
    California, MD
    i am talking about the outside of it! This thing looks like it was dunked in oily mud and then baked on!
  4. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    i bet it was exatllly that.
    twisted wire wheel cup on a grinder will take care of the big stuff.
    i uuse industreal lauqure thinner from an automotive paint suplyer with a paint brush and a plastic tub to de grease stuff
  5. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    Putty knife, oven cleaner, and purple power.
  6. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Any or all of the above and I would add to let the degreaser soak in.
  7. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    yup, scrape it first...
    easy-off soak,
    hot water rinse if possible,
    good degreaser soak ie:Spray 9, Purple Power, laundry detergent, etc,
    hot water scrub with a scuff pad...
  8. littlejimmythatcould
    littlejimmythatcould 1/2 ton status
    Feb 6, 2006
    797
    Clovis, NM
    Give this stuff a shot. It is meant for soaking and cleaning. It worked great on all of my engine fasteners and brackets when I did my rebuild. Obviously, you can't fit your tranny in there, but maybe you could put it in a spray bottle and use it to soak down your tranny and keep it wet. It will take the skin off of your hands if you use it long enough (it ate through all of my cheap latex gloves).
  9. greythorn3
    greythorn3 1/2 ton status
    Oct 14, 2002
    174
    Anchorage alaska
    cleaning parts
    I like to use diesel fuel.. CHEAP and works great at the sticky grime.. use a old 55 gal barrel and cut the top 2/3rds off and put diesel in it and splash it around.. or if you wanna get fancy u can put a 12v fuel pump on it with a sprayer and wire brush or just have it run over it.. iused a old fuel tank one time, just cut the top off it.
    Ray
  10. sweetk30
    Nov 1, 2004
    25,554
    548
    horseheads , ny 14845
    car wash or pressure washer. with steam option.
    at work i just blased a bellhousing with 1/8 inch gunk off in no time with cold only.
  11. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,496
    1,206
    So Cal.
    LET IT SOAK for atleast 3 maybe 4 days in some good solvent, works everytime for me.
  12. skyyk5
    skyyk5 1/2 ton status
    Jan 2, 2007
    1,537
    N.E. PA
    I am also doing a 465 & 205. I strapped them on the back of the flatbed and took them down to the car wash. $10 later they were really clean, and I was covered.:D Worked great though, My tranny had a inch of crap on it (old farm truck, might have been crap!). It looked new when done. The 205 still had the tag on it!
  13. skyyk5
    Jan 2, 2007
    1,537
    N.E. PA
    I'm also going to hit it with a wire wheel. It's going to go through an acid wash, then get powdercoated at work.
