Parts Falling Off
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1990SilveradoK5, Jan 24, 2001.
  1. 1990SilveradoK5
    1990SilveradoK5 1/2 ton status
    Jan 2, 2001
    185
    Napoleon, OH
    Take a look at the picture I have in my folder on yahoo.
    http://photos.yahoo.com/kjkmbabound
    I was walking out of the building today at lunch and saw this part hanging out from under my truck. It was stuck between the inner fender and the plastic splash gaurd in the front wheel well.
    What is it?
    Do I need to find put it back in or is it extra? LOL
    Gone Large and Loving It.
    Keith
  2. dyeager535
    26,980
    spark plug heat shield
    Dorian
    My K5 and Chev/Olds tech/links page: <A target="_blank" HREF=http://yeagerd.home.mindspring.com/index2.html>http://yeagerd.home.mindspring.com/index2.html</A>
  3. walt88
    walt88 1/2 ton status
    May 24, 2000
    430
    Monmouth County, NJ
    You probably ran over it in the road and it got stuck in the fender. Because i have no clue WTF it is.
    Keep the shiny side up, and the greasy side down.
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    http://albums.photopoint.com/j/Albumindex?u=1329584&a=9886502
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    dyeager got it. It's a spark plug heat shield. It should have been held in place by those two tabs, via the bolts that also hold on the exhaust manifold. Have those bolts fallen out or did someone not bother to reinstall the shield correctly at some point?
  6. Panther
    Panther 1/2 ton status
    Aug 31, 2000
    845
    South Jersey
    Just in case you still have doubts, Harry and dyeager are right. Check which one is missing under the hood.
    I wouldn't drive it real far like that honestly. You don't wanna ground your plug wires!! Make sure the plug wire isn't already laying on the pipe if you are gonna drive it anywhere.
    <font color=blue>"It's just a differentialator....Totally unnecessary" [​IMG]</font color=blue>
  7. 1990SilveradoK5
    Jan 2, 2001
    185
    Napoleon, OH
    I will have to drive it to Class tonight (Graduate School takes forever when working full time, 3 years down and 3 to go) then home about 40-50 miles. To damb cold to do anything in the parking lot here at work. Did look at the wires, all are held up away from the manifold.
    The DPO did mention he replaced plugs and wires, it has the blue splitfire wires on it. Shouldn't of had any reason to have this shield off to do that, would he?
    O'well can't do anything about the past.
    Keith
  8. Panther
    Aug 31, 2000
    845
    South Jersey
    Maybe he took the shield off to get at the plug and didn't put it back on completely right. Or maybe it just fell off [​IMG].
    You should be alright for a little while. Just check the wires as often as possible to make sure they don't end up in the headers.
  9. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I can't think of any reason to take the shield off. It's not in the way of anything and you have to remove the bolts holding the exhaust manifold to the head in order to remove it.
    Does your Blazer have headers on it? Perhaps the shield got dropped into the fenderwell area as the old manifolds were being removed.
