Parts for sale and deliverable to Portland in April
Discussion in 'Pacific Region' started by mountainexplorer, Feb 22, 2006.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    Here's a bunch of stuff I'll probably be selling off. In April, I can deliver most of this stuff to the Portland area. Most of this is for sale to raise fuel money to get to the Swap Meet and back.
    GM 14 bolt full-floater 3/4 ton rear end, 8-lug, complete drum to drum, $150.
    Part-time conversion for NP203 T-case, comes with housing and good chain (was a good working 203 but the range box and adapter got used for a doubler). Everything except the range box for $50. (chain, housing, shifter forks, tailhousing with part-time kit.
    1976-1980 K5 Blazer top $30.
    1973-1975 K5 Blazer top $35.
    Steel bellhousing for SM465 manual transmission $20; aluminum bellhousing $20
    Hydraulic bellhousing for SM465, bellhousing only (no other parts available), came out of an '88 Suburban, $85.
    SM420 4spd 2wd tranny, $ any small fuel donation of your choice.
    Tranny to T-case adapters: SM465 to 208 $25; TH350 to 208 $25; 700R4 to 208 $25; TH400 to 208 $35; TH350 to 203- any offer
    Pair of rear barn doors off 1974 Suburban, no dents, one small rust spot inside, but not bad. Otherwise in good shape $80 for both with mounting hardware.
    Suburban rear tailgate with glass and manual rolldown, off a 1976, not perfect cosmetically but worked good, $25.
    Roll bar for 1973-1975 K5 Blazer $50.
    1973-1980 hood, $15
    Rear slider window for 1973-1987 truck cab $10
    Light blue dash pad in good shape for 1973-1980 $65 (hard to find these not cracked)
    SBC stock intake manifolds, exhaust manifolds, free with small fuel donation.
    Misc rear drivelines, some with 1350 ends and slip yokes, carrier bearing styles, open to offers depending on what you need.
    Dana 44 and 10-bolt front axleshafts, inner and outer, pass and drivers sides. Open to offers.
    Chrome SM465 shifter $15
    Frame mount hitch, bolts onto truck frames. Takes a 2" square tube stinger. Not sure on it's capacity. $40.
    Hitch for Suburban $40
    some 52" and 56" rear springs $20/pair
    Steering boxes $20 each
    Hydroboost brake booster and lines $75
    1973-1980 front bumper with painted steel grille guard/brush guard $50
    Straight bare Dana 44 and 10-bolt front housing, free with small fuel donation
    Fan shroud (one piece) for tall 4-core radiator and big block motor in a '73-'80 truck, $20.
    1983 Chevy Scottsdale 3/4 ton 4x4 with 6.2 Diesel, 92,000 original miles, SM465 4spd, NP205, 14-bolt full-floater rear, 10-bolt front, 4.10 gears, 3" lift. In the past year: new high torque starter, recently replaced injectors, alternator, glow plugs. Body pretty straight, needs front right fender and trim replaced. Comes with spare fender. $1900
    And here's stuff WANTED: Things friends of mine will be looking to buy when they are down with me.
    Accessories: Cab Sun Visors/Moon Visors, other bolt on accessories, steps, etc.
    Complete 454
    Good seat for a 1967-1972 truck
    motor parts: aluminum intakes, SBC or BBC gear drives, Edelbrock carb, roller rockers.
  2. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    if i recall correctly - suburban tail gates do not fit blazers, right?
  3. mountainexplorer
    Nov 14, 2001
    4,903
    They are different.
    I might have one for a K5 if I don't end up using it on my '84.
  4. wkbrdrob
    wkbrdrob Registered Member
    Feb 7, 2006
    63
    Salem, OR
    might be interested in the SM465/208 adapter. Let me check something and I'll get back to you....
  5. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Maybe we should make this the offical Portland Swap Meet thread... I have a ton of extra stuff I'm gonna sort thru this weekend and make up a new list...
  6. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    let me know. my buddy needs a new tailgate - his electic one is a pita.
  7. mountainexplorer
    Nov 14, 2001
    4,903
    Oh ok, you need a manual crank one. The K5 tailgate I have for the spare is electric.
    If anyone else is going to the swap meet, or wants to barter/sell stuff beforehand, post up. I'm planning on going down there a few days beforehand to have time to take care of non-swap meet deals (and to ensure I get there on time- not taking 15 hours and hopefully I won't go through 20 quarts of oil and have to replace a timing chain again)
  8. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    actually, i think he'd be more inclined to the electric one if yours works well. I said manual just because they're easier to maintain. maybe he should just rebuild his motor - idk. in anycase, let me know when the time gets closer. i'll let him know about this. :)
  9. 89-Blazer
    89-Blazer Registered Member
    Nov 14, 2005
    19
    Vancouver, WA
    Are the 10 bolt axle shafts 28 or 30 spline? If they're 30's I might be interested in those.
    Mike
  10. mountainexplorer
    Nov 14, 2001
    4,903
    Ok, my trip to Portland is fast approaching, possibly as soon as Monday the 3rd or Tuesday the 4th.
    I'll have to check on the shafts I have and see what they are.
    I'll update and add a few things here soon.
  11. K5Kell
    K5Kell Guest
    Those SBC exhaust manifolds wouldnt be from a '87-'91 blazer would they?
    -Kell-
  12. mountainexplorer
    Nov 14, 2001
    4,903
    Sorry, those are all mid 70's ones that I have.
  13. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    And the wife said no more hardtops, I was creating a santuary...
  14. mountainexplorer
    Nov 14, 2001
    4,903
    Haha. Did you ever use that one?
  15. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    i could always use another set of 56s. You're coming by anyway to grab those tires/wheels right?
    j
  16. mountainexplorer
    Nov 14, 2001
    4,903
    I almost forgot about those wheels. I think I only have 1-ton 56's left, but thats what you wanted anyways, right?
  17. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    only difference is that 1-tons have more leafs right? Thats fine, I'm all about custom packs anway. :thumb: So long as the main leaf isn't pitted all to heck, I want 'em. :thumb:
    j
  18. mountainexplorer
    Nov 14, 2001
    4,903
    What were the 56's for? I pulled one set out of a truck last weekend (only took like 3 hrs :doah: ), and have one more pair to pull out of a 1-ton Crew Cab before I leave.
    I have you needing a pair and one other person, so I don't know which of you want what pair.
  19. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    they will be going in my K5, of course. Front or rear depends on how good'a shape the main leaf is in...
    j
  20. mountainexplorer
    Nov 14, 2001
    4,903
    Ok, for some reason I was thinking you wanted others for the 2wd truck. I'll just have you look at them and pick out. You get first pick.
