parts interchange-ability
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by coolhandluke, Jun 18, 2002.
  1. coolhandluke
    coolhandluke 1/2 ton status
    Oct 23, 2001
    116
    Dallas Texas
    I need 2 parts,
    1. front driveshaft
    2. dust cover for front brakes (thing that goes behind the rotor that the caliper mounts on)
    I have an 83, diesel, what years/models could I pull these parts off of?
  2. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    What transfer case? As for the dust covers, any ten bolt, D44 ought to work.
    John
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    As far as the disc brake shields go, get rid of them. I took them off and now less crap gets stuck between them.
    As far as driveshafts go, you should get one from a truck with the same front axle as yours and the same tcase.
    -- Mike
  4. coolhandluke
    Oct 23, 2001
    116
    Dallas Texas
    how do you mount the caliper if you get rid of them?
  5. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    The shields are spot welded in four places, I believe, to the caliper mount. You can take a 4 1/2" grinder and get the shields off and throw them away.
    When I did it, I had the mounting brackets off the truck because I was putting in new balljoints. I don't think it would be very easy to get to them with them on the truck, but I could be wrong.
    -- Mike
  6. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    On my 82 when i ran a turbo350 with a 208 t/case i used the front drive shaft from a 91 with a 700r4 and 241 t/case with no problems it bolted right in place on the 208.
