Parts Interchange Question?
Discussion in 'The Garage' started by Chevy305, Nov 23, 2006.
  1. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    So I plan on getting a 14bsf shortly from a 81-87 chevy truck so i won't have to move the spring perches. But i will also want to convert it to 6 lug. So my question is that is the newer body style (88-up) 14bsf 6 lug axel shafts interchangable with the older style 8 lug shafts? Also I guess I'd have to get new brake drums too, so are those interchangable too?
  2. JohnDeere
    JohnDeere 1/2 ton status
    Jan 17, 2006
    342
    Houston, Texas
    I dont think you can change them out because in 87 they went to metric on axle lugs
  3. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    lug studs are an easy change, however, i would advise against using the pre-88 housing. its much easier and cheaper to move 2 perches, and 2 shock mounts than it is to buy and swap 2 axle shafts and 2 complete brake assemblies.
  4. MaxPF
    MaxPF 1/2 ton status
    Apr 13, 2006
    2,207
    Chandler, Arizona
    What he said ^ ^ ^ :thumb:
  5. diesel4me
    Jul 24, 2003
    17,577
    945
    Massachussetts
    nope....
    The 88 and newer 14 bolt SF axles are wider,so I doubt the shafts would swap into an older one..you have 2 choices,get a newer 6 lug SF and re-weld the spring perches in the correct location,or use an older one that will bolt right in,and bring 2 spare tires,one 6 lug rim and one 8 lugger...but if you go with an 8 lug SF,you might as well buy a FF axle instead..
    I wonder why there isnt any "dual bolt pattern" rims for 6 and 8 lug trucks...I have several "space saver" rims that have 10 holes,to fit the 4-3/4" or 5" lug pattern on 2wd S10's and C10's....they should market some dual pattern rims so we wont have to swap 8 lug outers on the front too!..:crazy:
  6. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    something about 2 lug holes lining up exactly, making it necessary for 2 elongated lug holes, not a good idea at all.
  7. Chevy305
    Jan 23, 2006
    11,232
    490
    New Hampshire
    The problem is I don't have a welder. But actually, my neighbor does. So I will have to see. Swapping axel shafts is no biggy, or the brakes for that matter.
    Are the 88 and up 6 lug brakes the same as the older style 8 lug brakes? Is it just the drums that are different, or is the entire brake setup different?
  8. tomford
    tomford 1/2 ton status Premium Member
    Jan 19, 2006
    921
    7
    New Hampshire
    i have a 10 bolt front and 14bolt FF rear 8 lug for sale.......
  9. MaxPF
    Apr 13, 2006
    2,207
    Chandler, Arizona
    It's not that swapping axle shafts and brakes are difficult. It is simply that you will wind up spending double the money, making the swap much less cost effective. The whole point of doing a 14bsf swap is to add beef at minimal cost. :deal: Otherwise, you might as well swap in a 14bff, an 8 lug 10b or D44 front, and get a set of 8 lug rims :tongue1:
    If you don't have a welder (or adequate welding skills) then cut the perches and shock mounts off, clean up the tubes, perches, etc. and mark where they need to be welded. Then have either a buddy with a welder or a shop weld 'em on for you. Be present with a tape measure and angle finder so you can double-check the location and angle of the perches and mounts after they tack em up.
