Parts laying around! What is still on the drawing board for everyone?
Discussion in 'The Garage' started by zakk, Sep 7, 2002.
  1. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    I have all the pieces for the following:
    1.Crossover Steering (box on the way)
    2.Shackle flip
    3.Rock Sliders
    4.Breather relocation
    5.Trailbox & spare mountings
    Do you have anything you are to busy/lazy to install right now? /forums/images/icons/laugh.gif /forums/images/icons/wink.gif
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Everything! /forums/images/icons/laugh.gif I'm too busy/lazy to even type out my list... /forums/images/icons/crazy.gif
  3. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    Im getting ready for a run in Fla. Heres my list from the post about getting ready for it.
    Lets see...
    1 finish brakes on new axles
    2 get front gears and get them in
    3 get axles swapped
    4 get rims swapped
    5 install Hydro Boost
    6 shackles
    7 maybe lift a few more inches
    8 change windshield
    9 get wipers so they are in the DOWN position when off. LOL!
    10 Oh yeah new shaft for the rear
    11 try to strip out interior
    12 make an attempt to get 1/2 doors done
    13 make a front receiver
    14 maybe swaybar discos
    15 adjust valves
    16 change cooloant to green type, RED COOLANT SUX!
    17 install 2nd battery tray and at least have a back up battery on hand
    18 try to get atleast front bumper built
    19 get my CB working properly or get another
    20 change oil, lube EVERYTHING
    21 build front to back vent tube for axles Tcase and tranny
    22 try to get a chance to find/fix oil leak
    23 clearance front shaft
    This is just a start. Ill add more to it as I think of it.
    THEN I need to get stuff to take.
    1 get another first aid kit
    2 collect up all my straps
    3 get a few extra ujoints
    4 TOOLS
    5 tent
    6 clevis
    7 at least 1 more fire extinguisher, preferably 2 already have 1
    Ill never get all this done!
  4. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i gould work on my motor. tear it appart rest of the way an start buying parts.
    just got the stuff for manual conversion.
    got a few crossmembers to install.... some day.
    took 2 months to finish cutting the fenders...
    and i need about 10k more in green to get on theroad again....
    grant
  5. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Oof, I don't know if I even want to think about how much I have going on right now... Let's see...
    Dana 60, the housing is cleaned and ready for install of the following, which I already have -
    ARB
    5.13s
    35 spline outers
    Warn premiums
    14bFF, this housing should be cleaned and ready for building by this evening. All I have for this right now is the 5.13 gears, but a carrier with welded spiders should be on the way next week. Disk brake conversion parts will be ordered next week, then crossover steering soon after that, quickly followed by a hydro assist setup.
    Rockstomper beadlocks will get ordered probably early next month.
    Also have a complete York OBA setup planned, mostly assembled and ready to rock, I just need to make a mount for the compressor. Here are some pics of the main pieces for the OBA. The tank isn't shown, but it's a 6.5 gallon job that will go under the bed.</font color>
  6. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    I still have a bunch of stuff too. Got plenty of time to do it but not enough money. Before the Fl run I have to lift it, and it looks like Im going to have to run all new springs cause my back is sagged crooked in the rear /forums/images/icons/shocked.gif Need tires, gotta get it aligned, and need some pare parts in general. I didi get some stuff done though. Yesterday I got my battery secured so it won't fly off and hit the fan, got the rear diff serviced, took my amp and sub out and found a tool box im going to bolt done it their place /forums/images/icons/laugh.gif
  7. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    I find THIS ironic, I couldn't wait to get a Dana 60front; now that I have one, I am too lazy to swing it under my truck. No mounting issues, it's the same gear ratio as my rear, have the block for the steering arm, just too damn lazy to get it done. /forums/images/icons/crazy.gif BUT, the rear is getting disc brakes today (thanks DERBINATOR) and new rear perches (thanks rockjunkies). I just have to decide if I am too lazy to bend the hard lines on the axle. /forums/images/icons/grin.gif
  8. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I don't even want to make a list! if I actually saw what still needed to get done, I would most likely get mad and sell it!! (not really). relift truck, parts on order. cross over steering, parts on order, make wire harness and get the pig running!!
  9. aksidentproan
    aksidentproan 1/2 ton status
    Dec 8, 2001
    477
    Maryland
    For once in my short life, I'm not being lazy today. This is what I got done today:
    -Installed New engine
    -Installed new motormounts
    -Headers
    -clutch linkage
    -new clutch
    -new flywheel
    -rewraped entire wiring harnass
    -painted engine compartment(firewall and inner fenders
    This is what I need to do before she runs again:
    -install 2" body lift
    -new body mounts
    -4.56's in both axles
    -powertrax No-Slip in rear
    -hook up radiator
    -carbuerator
    -starter
    -battery
    -hood
    -radiator support
    -grill
    Evan
  10. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    Same here...the D60 is just sitting in the carport. i have a few things i need for it though. Some kind soul is sending me a steering block soon, I'm about to order the weld on ends from avalanche so I can build a rock-rod of sorts. I will also be doing rear disc's before the new 14 goes under the truck...gotta order brackets soon.
    The number two thing I need to do at the moment is send in my $25...the money order is just sitting here on the desk/forums/images/icons/smile.gif
    Finally my number one thing to do is pull the welded spiders out of my diff for Shaggy...then I can ship the carrier and spiders finally!
    Damn I feel lazy... /forums/images/icons/tongue.gif
    Rene
  11. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    1. FLywheel cover (need to buy some bolts so I can put it on)
    2. Corvette Exhaust Manifolds (need to find some manifold studs for use w/o heat riser first)
    3. Front reciever hitch (need to get off my lazy butt and finish welding it together, buy I need to buy an oxy torch before I can finish it)
    I guess that's it. I have lots more plans, but that's just the stuff lying around.
    -- Mike
  12. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    i gatta do my whole damn floor and rockers! and outside body work then get it repainted, gatta put some new tires/wheels on and then it should be in good shape..then goes the lift..BIGGER tires..light bar, rhino lining, and a bunch of other stuff i cant think of..
  13. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    im rebuilding my engine, and i realized that the engine was bored 30 over after i ordered the pistons, well now i hafta to send em back, they've been sittin in my car and today i decided to get a box and styrofoam snow to pack it in.
    phill
  14. stump_puller
    stump_puller 1/2 ton status
    Apr 5, 2002
    871
    135
    Corbin, Kentucky
    Got my truck fully disasmebled almost finished painting the frame.
    After that:
    Take heads off to fix BIG smoking problem.
    Cut out floor from my smashed 4wheel drive cab and weld to the new 2wheel drive cab.
    Order new fenders,hood,pass. door and bedsides.
    Paint all new sheetmetal
    reasemble and hope to god I remember how it all went back together(wiring harness).
    and some other misc. things
    After all that:
    ENJOY /forums/images/icons/grin.gif
  15. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Well, about 6 months ago, I made and mounted a slider on the drivers side of my truck. 3 weeks ago I got around to makin up the one for the other side...And it's still sittin in the shop as e speak. /forums/images/icons/grin.gif
  16. 87GMCJimmy
    87GMCJimmy 1/2 ton status
    Nov 21, 2001
    582
    Phoenix, AZ
    3/4 ton axles in the side yard, new 35 inch baja claws on 8 lug 589's. I still need to finish the Vortec install, getting close but I've just been working too much lately. Lastly, pick up more beer because I'm drink'n my last one right now!
    Mike
  17. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    I have a rear Dana 70HD that I'm building but I just can't get motivated to finish it. I had it narrowed to normal width, I finished the rear disc brakes using front D60 parts, I have all new bearings and gears (5.86). All I need now is to order some custom length Moser axles but I'm just too lazy to assemble it to get an exact measurement. /forums/images/icons/crazy.gif
  18. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Let see.....
    On K-5
    1. Paint Shell Black
    2. Install TPI System /forums/images/icons/ooo.gif
    3. Find and install New Transmission /forums/images/icons/smirk.gif
    4. Re-carpet Front and Back
    5. Wire Power Rearview mirror (Compass)
    6. Wire Power Door Locks into Alarm
    7. Make Sliders
    8. Tint Windows (Doors and Tailgate)
    9. Install CB Antenna
    10. Install Cell Phone Hands Free Unit
    /forums/images/icons/confused.gif (I know I forgot something!) /forums/images/icons/confused.gif
    H-D xlch /forums/images/icons/cool.gif
    1. Lacing Rear Wheel
    2. Get and Install Tires
    3. Finish rebuilding Engine and Trans.
    4. Finish Polishing
    5. Finish Putting togather
    Porsche 944
    1. Timing Belt /forums/images/icons/tongue.gif
    2. Replace Passanger Door /forums/images/icons/mad.gif
    3. Re-paint back to original Color (Red) /forums/images/icons/wink.gif
    4. Re-install Alpine Deck
    5. Re-tint Windows
    6. Sell /forums/images/icons/smile.gif
    Also need to keep up 4 houses. Work and Daughter's activities.
  19. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I have the following:
    4" BDS springs (front &amp; rear)
    ORD Shackles
    ORD greasebla bushings
    4" Steering arm
    Still need to get:
    Shocks
    12 bolt
    35's
    Wiper module
  20. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Boy do I fit this Category well. I have had some of these parts since the Fall of 2001! Here goes:
    1. Clocked WMS Dual Transfer Case NP203/NP205 - This setup will allow flush frame crossmember like Watson's.
    2. TH350
    3. Fresh 350 with Pro-Jection system
    4. Missouri Offroad Outfitters Shock Crossmember
    5. Rock Ram Hydro Assist Steering
    6. On Board Air system
    7. Add a few bars to the cage
    8. Rocksliders - built in (a Must!)
    Things I have recently bought and will be selling because I am purchacing a matched 4.56 geared 1 ton setup (Oh Golly, I get to change my signature again!)
    1. 4.56 Gears for Dana 44 and 12 Bolt
    2. Detroit Lockers for Dana 44 and 12 Bolt
    3. Warn Shafts for Dana 44
    Now that I have changed the idea to 1 ton, I will have to buy and install the following out of necessity. /forums/images/icons/smirk.gif
    1. Dana 60 ARB Air Locker
    2. Dana 60 Crossover Steering Arm
    3. Disk Brakes on the 14 Bolt
    4. Custom Beadlocked 8 Lug rockcrawler rims - I designed a set of rings similar to the Rockstompers.
    5. Hydroboost Assist Brake System
    My want list is here:
    1. BorregoK5 Shackle Flip
    2. 42" Super Swampers
    3. A MOO built Neil designed front bumper
    3A. A Daisy Red Rider super carbine air rifle with a compass in the stock. /forums/images/icons/wink.gif
