Parts Solvent
Discussion in 'The Garage' started by rpellicer, Apr 22, 2005.
  1. rpellicer
    rpellicer Registered Member
    Dec 20, 2004
    38
    Susanville, CA
    I just got a 20 gal. parts washer from Harbor Freight. It says to use water based solvent. Any suggestions of what solvent to use? (can't run my old favorite - kerosine)
  2. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    I run power purple in mine. Not sure if it is water based though.
  3. tunedportk5
    tunedportk5 1/2 ton status
    Jul 13, 2004
    371
    Union City, CA
  4. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    We have a barrel of this stuff at work, I thinkits like isopffranic (SP?) or something, works great, but our machine recycles it every night, so its always clean!
  5. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    I just picked up the same washer and I'm running into the same problem. I never thought to check what type of solvent it would handle :mad: . I just figured I'd dump some PD-680 in it and go.... I'm looking for something that I don't need to wash off with water after I'm done cleaning the part. I'll let you know what I come up with if I find a suitable solvent before you do.
  6. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I have a parts washer from HF. We put Castrol Super Clean/Purple Power mixed 50/50 with water in it. Cleans great, but the pump died pretty fast. I think that what ever it is in that stuff ate some of the pump's parts like it eats the skin off your hands.
    If you weld a pipe bung on the side of the tank and put one of those immersion water heaters in the tank the solvent works WAY better.
  7. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    I know the Simple Green will eat through a metal container over time. We had 55 gallons stored in an overhead storage tank a few years back and came in on a Monday to find a hole in the tank and a very nice smelling shop. I can just guess what it would do to my cheap parts washer....
  8. rpellicer
    Dec 20, 2004
    38
    Susanville, CA
    PD-680? That sounds familiar. Is that used for cleaning aircraft?
  9. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    Cleaning solvent we used in the parts washers when I was in the military. I'm sure it was used on the flight line too.
  10. muscle
    muscle 1/2 ton status
    May 28, 2000
    408
    Show Low, AZ
    I dont understand why the washer is limited to using only water based solvents? I use mineral spirits (paint thinner) and its works great and cheap too.
  11. rpellicer
    Dec 20, 2004
    38
    Susanville, CA
    I'm assuming it's to reduce the fire hazard. Also the pump has some plastic parts which probably could be eaten up by some solvents.
  12. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    I bought my parts cleaner solvent @ harbor feight. Says to mix with water, but I found it worked better not diluted. Just costs a bit more :grin:
  13. smalltruckbigcid
    smalltruckbigcid 1/2 ton status
    Dec 25, 2004
    3,866
    3
    NE Wyoming
    Bought my cleaner at northern tool....$5.-6. a gal I think, no mixing
    George
  14. patches85
    patches85 Registered Member
    Jan 17, 2005
    51
    Lewistown PA. the armpit of the state!
    Castrol Super Clean. My Dads buddy is a machinist and probably one of the sharpest guys I know and he built a parts washer and thats what he uses. Takes paint and everything off if you leave it in there for a couple of days, just don't get it on your bare hands!
